Network DVR & Analogue CCTV Cams. How much, Where etc?
Old 06-10-2009, 7:29 PM   #1
calibos's Avatar
8,425, Level: 21
Points: 8,425, Level: 21 Points: 8,425, Level: 21 Points: 8,425, Level: 21
Thanks: Gave 18, Got 29
Can anyone tell me how much dosh are we talking about for 3 outdoor analogue cameras wired back to a DVR with network access. Based on some threads I read after a search, it seems that IP cameras are not for me. Analogue are cheaper, DVR saves me having to use a PC or server to record. However I would like to be able to view the footage live on Network streamers (XBMC) spread around the house
BTW, Low light is not an issue. Front and side of house is lit up like daylight be Orange streetlights and back yard has a motion sensitive fllodlight.
How much are we looking at? What brands should I be looking at? Where should I be looking for them?
Thanks in advance
Old 07-10-2009, 9:16 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Network DVR & Analogue CCTV Cams. How much, Where etc?
not sure about XMBC but there are cheap options from maplins/costco etc, better ones from Y3K and a few others, then mor eexpensive ones from Dedicated mircos etc
loof for a 4 channel DVR and some day/night cams (switch to BW in dark)
