CCTV Advice needed please...
Old 04-10-2009, 3:03 PM   #1
2,977, Level: 12
Points: 2,977, Level: 12 Points: 2,977, Level: 12 Points: 2,977, Level: 12
Thanks: Gave 7, Got 0
Question CCTV Advice needed please...
The choice of cctv systems is crazy! So much choice - and very little reviews on the products
Can anyone help please...
I don't mind buying it all separate - and i'm in the UK if that could help anyone to suggest some items.
4 x Colour in day time / b&w night cameras. Really high quality. The best i can get for £150ish each. (So many features available im confused!) They need to record at 50m in the dark - so need IR, and that feature that stops the IR from blanking out faces with too much IR in one place. Style i dont mind. (Auto focus?)
1 x DVR - that can record 4 cameras at once, with audio. It dosnt need to work over the internet or anything like that. Just record, playback, and maybe export to USB. I'd say up to £300 for this. If it can detect movement to record etc, that would be great also.
Can anyone help with the above please?
Thanks so much for reading! CCTV is driving me crazy! lol.
Old 27-10-2009, 11:12 AM   #2
JLA JLA is offline
2,655, Level: 12
Points: 2,655, Level: 12 Points: 2,655, Level: 12 Points: 2,655, Level: 12
Thanks: Gave 14, Got 16
Re: CCTV Advice needed please...
Byron door chimes, wired chimes, wirefree chimes, bells, bell pushes
View this site and click on CCTV tab, They also sell this in Makro so if you have a membership pop in and have a look. There are numerous quad systems and IR boosters available to increase the night vision.
I would suggest:
http://www.chbyron.eu/product_detail...=82&prodid=437
or
4 of these would give better quality http://www.chbyron.eu/product_detail...=82&prodid=441
http://www.chbyron.eu/product_detail...=82&prodid=442
http://www.chbyron.eu/product_detail...=82&prodid=540
But there are other kits available, if you need more info im happy to help.
Hope this helps
