Where do I start my research into RC lighting?
Old 21-09-2009, 10:06 AM   #1
music's Avatar
5,727, Level: 17
Points: 5,727, Level: 17 Points: 5,727, Level: 17 Points: 5,727, Level: 17
Thanks: Gave 36, Got 14
I have a large studio room where I have all my AV equipment etc. I would like to install dimmable downlighters and wall lights etc.
I would like to be able to control these with a remote control, preferable a system that can be controlled by the same remote control that controls the AV equipment etc. I believe this may be possible?
Can anyone giver me any pointers as to where to start looking and learning about what sort of products are out there and the costs etc?
Many thanks
M
Old 21-09-2009, 10:08 AM   #2
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,844, Level: 38
Points: 24,844, Level: 38 Points: 24,844, Level: 38 Points: 24,844, Level: 38
Activity: 12.9%
Activity: 12.9% Activity: 12.9% Activity: 12.9%
Thanks: Gave 598, Got 1,310
Re: Where do I start my research into RC lighting?
Originally Posted by music View Post
Many thanks
M
i had standard downlighters in my cinema room, replaced the switch with a remote controllable switch from varilight i picked up at b&q. my harmony remote had the codes for it, so i can now switch on/off or dim my lights from the remote....
Old 22-09-2009, 4:01 PM   #3
JLA JLA is offline
2,655, Level: 12
Points: 2,655, Level: 12 Points: 2,655, Level: 12 Points: 2,655, Level: 12
Thanks: Gave 14, Got 16
The issue with the varilight ones is that they are infrared?
The Homeeasy range is RF allowing better control through walls and ceilings. There are various threads about homeeasy here.
http://www.avforums.com/forums/home-...range-b-q.html
Old 23-09-2009, 10:43 PM   #4
music's Avatar
5,727, Level: 17
thanks for that.
But - am I right in thinking that IR (rather than RF) is the sytem that all-in-one rc's like the Logitech Harmony range use, so I can use my hi-fi/home cinema rc to control them too - rather than having yet another rc to tangle with and lose?
Old 24-09-2009, 8:00 AM   #5
mossym's Avatar
24,844, Level: 38
Activity: 12.9%
thanks for that.
yup the harmony's use IR, i'm using a harmony to control my lights...
Old 24-09-2009, 9:17 AM   #6
Assured Advertiser
Liam @ Prog AV's Avatar
27,664, Level: 40
Points: 27,664, Level: 40 Points: 27,664, Level: 40 Points: 27,664, Level: 40
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Thanks: Gave 6, Got 803
Yep for a programmable remote to work it needs IR lighting. I would usually put Rako bits in (the various Rako parts communicate wirelessly) and then install a Rako-IR receiver in the rack or directly onto a wireless extender for the remote. You get discrete codes for each room and each light etc. Very easy retrofit with Rako too.
How much does a cockney pay for shampoo? Pantene
call me: 01892 860801 / e-mail me: liam@progressive-av.com / twitter me: @ProgressiveAV
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Old 24-09-2009, 9:19 AM   #7
mossym's Avatar
24,844, Level: 38
Activity: 12.9%
i guess the big question is do you need multiple rooms to e controlled and do you want to be able to switch them when you are not in that room?
Old 01-10-2009, 8:07 PM   #8
Jamie's Avatar
10,760, Level: 24
Points: 10,760, Level: 24 Points: 10,760, Level: 24 Points: 10,760, Level: 24
Thanks: Gave 93, Got 573
The NG series of Prontos (RU950, 960, 980 and 990) can directly control the Homeeasy kit. and also X10 with the X10 RF thingy
