Best Wireless Intruder Alarm
Old 09-09-2009, 10:05 AM   #1
2,753, Level: 12
Points: 2,753, Level: 12 Points: 2,753, Level: 12 Points: 2,753, Level: 12
Thanks: Gave 2, Got 0
I know there are other threads on this subject but have found none that specifically address this question. Apologies, however, if it's already been answered.
Because of problems of disturbance with the installation of a hard wired system I am intending to install a wireless or hybrid hard wired panel with wireless sensor intruder alarm.
With the almost daily technological change I wonder if anybody can give me a recommendation as to the best alarm system available. The alarm is for a large domestic property.
Old 09-09-2009, 5:06 PM   #2
D4RK1's Avatar
2,557, Level: 11
Points: 2,557, Level: 11 Points: 2,557, Level: 11 Points: 2,557, Level: 11
Thanks: Gave 27, Got 20
Re: Best Wireless Intruder Alarm
How many zones (pirs/doors etc) do you require???
Check out guardall for the panel and visonic for the detection.
Old 10-09-2009, 8:52 AM   #3
2,753, Level: 12
Thanks for the reply DR4K1.
There are 4 doors to the house and I think 5PIR's should cover all routes.
Old 10-09-2009, 2:04 PM   #4
JohnS's Avatar
9,453, Level: 23
Points: 9,453, Level: 23 Points: 9,453, Level: 23 Points: 9,453, Level: 23
Thanks: Gave 6, Got 30
The newest system on the market comes out next month made by GSD and is the "only" grade 3 wireless system available so will be the best.
Today I would fit a Scantronic hybrid or the Risco Agility if you want a completely wireless solution including the siren and remote keypad.
Old 11-09-2009, 5:28 PM   #5
2,753, Level: 12
Thanks JohnS.
I think I'll wait to next month for the GSD
Old 11-09-2009, 8:26 PM   #6
JohnS's Avatar
9,453, Level: 23
You should get an installer to come and do a risk assessment and work out if you "need" it, its likely to be quite a bit more expensive. There really is nothing wrong with a grade 2 system if it meets your required risk and satisfy's your insurance company.
Old 12-09-2009, 9:25 AM   #7
2,753, Level: 12
Thanks once again JohnS I'll do that.
Somebody has mentioned Infinity with a hard wired panel and bell and wireles PIRs etc. as being a good system.Does anybody have a view on this?
Old 12-09-2009, 7:10 PM   #8
JohnS's Avatar
9,453, Level: 23
A company called ESP make an Infinite, if that's what you mean. It can be brought through TLC. It uses a hardwired bell through a wireless interface that needs a mains connection, usually in the loft. I've fitted about half a dozen but not my preference.
Old 13-09-2009, 8:52 AM   #9
2,753, Level: 12
JohnS The recommendation was emailed to me and said "infinity", although that could be a spelling mistake.
I must admit the only "infinity alarm I can find is on www.wholesalesecurity.net/html/infinity_wireless_alarm_.html
I dont know if this is the ESP or not.
Old 13-09-2009, 5:06 PM   #10
JohnS's Avatar
9,453, Level: 23
Yes that's the ESP. Are you looking for diy or an installed system?
Old 15-09-2009, 11:41 AM   #11
2,753, Level: 12
JohnS. I'm getting a couple of quotes but I was originally looking at the best DIY system. Ultimately I'm looking for the best available. I've read adverse reports on some systems regarding interference and wireless range so I thought a commercial system may be better. I am fairly capable on electrical work.
Old 16-09-2009, 10:02 PM   #12
JohnS's Avatar
9,453, Level: 23
The ESP is the only one that you'll be able to buy easily as diy but I wouldn't describe it as a diy install, as with all wirefree systems there is lots of programming. The Scantronic hybrid is probably easier but not available to diy but we might be able to sort that The Risco Agiltiy is way beyond a diy install.
The best available isn't available to the diyers for lots of reasons. As I said before, it really depends what grade of system you need as a diy install will not be graded.
Old 17-09-2009, 11:44 AM   #13
794, Level: 6
Points: 794, Level: 6 Points: 794, Level: 6 Points: 794, Level: 6
permit me to join in this thread as i'm also pursuing the best wireless intruder alarm with the possibility of a DIY install.
John S: Today I would fit a Scantronic hybrid or the Risco Agility if you want a completely wireless solution including the siren and remote keypad.
John S: as with all wirefree systems there is lots of programming. The Scantronic hybrid is probably easier
Referring to a Scantronic Hybrid would this include the Scantronic ion 16. This is the system i've been looking at and D/L the installation manual last night. Reading through, it is well instructed. However like all things DIY (Do it yourself / destroy it yourself) before you dive in, it reads well but when it actually comes down to it, you find that its slightly more complex. Would you say the ION 16 is a practical DIY install?
thank you.
Metso
Old 17-09-2009, 3:35 PM   #14
5,063, Level: 16
Points: 5,063, Level: 16 Points: 5,063, Level: 16 Points: 5,063, Level: 16
Thanks: Gave 41, Got 31
Post Re: Best Wireless Intruder Alarm
I've been using a wireless system called Alertme for over a year now and Im very happy with it. You install it yourself and they provide fantastic customer support. System can call/text/email you and/or your alternative key holders and is very configurable through a user friendly secure webpage. Also can monitor your smoke/carbon monoxide alarms. You can add cameras to the system as well as SmartPlugs. More info on their website and a user forum that is very active by owners and customer service.
Good luck with your search for the right system for your home.
Old 17-09-2009, 6:20 PM   #15
2,753, Level: 12
With regard to these systems is there any advantage in choosing one with hard wired panel and bell? I 'm not sure about the others but I know the "infinite" has this.
Old 17-09-2009, 10:56 PM   #16
JohnS's Avatar
9,453, Level: 23
Originally Posted by metso View Post
thank you.
Metso
Again, the Scanny is probably easier that the ESP, I've fitted a couple but its fairly new. there are adavntages and disadvantages of both. Working out the terminology between maniufacturers is probably the hardest thing as they both describe the same thing differentley.
Old 17-09-2009, 11:05 PM   #17
JohnS's Avatar
9,453, Level: 23
Are you sure, the last infinte I fitted a year ago needed a wireless control module to a wired bell which makes it a bit of a daft otpion....
The Ion 16 uses a wired bell or one with a wireless module, the Agiilty uses a completely wireless bell. I'd use The Scantronic homelink 55 with a wired bell and remote keypad if possible or the Risco Agility if not.
Old 18-09-2009, 5:13 PM   #18
2,753, Level: 12
[QUOTE=JohnS;10397788]Are you sure, the last infinte I fitted a year ago needed a wireless control module to a wired bell which makes it a bit of a daft otpion....
JohnS I understand this is the case from a supplier - Both the panel and alarm are wired.
Had a quote from one installer today proposing to use Visonic Powermax. I've seen the latter mentioned in previous threads and assume that the Agility & Scantronic hybrid are superior to this?
Old 21-09-2009, 7:47 AM   #19
JohnS's Avatar
9,453, Level: 23
I haven't ever done a Powermax as when it came out a few years ago it fell done on a couple of things regarding the British Standards and I thought the rep was a d*** and couldn't deal with him.
I do know its been improved though but couldn't say how it compares.
