cctv on labgear distribution amp
Old 30-06-2009, 11:56 AM   #1
1,926, Level: 10
Points: 1,926, Level: 10 Points: 1,926, Level: 10 Points: 1,926, Level: 10
Hi I am in the process of buying a cctv kit with dvr , not sure of which yet but are looking at swann at maplins advice would be good but what I wanted to know if this could be fitted to my labgear distribution amp in the loft which is connected to my sky plus
what would I have to do to do this and monitor it on tvs around the house
Any diagrams would be greatly appriciated
thanks col
Old 30-06-2009, 12:27 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: cctv on labgear distribution amp
You will need a UHF modulator to convert the Video output of the DVR to the Input of the AMP
Old 30-06-2009, 3:55 PM   #3
1,926, Level: 10
hi do you know any links where they might have drawing of what to do
thanks col
Old 30-06-2009, 6:44 PM   #4
2,454, Level: 11
Points: 2,454, Level: 11 Points: 2,454, Level: 11 Points: 2,454, Level: 11
Thanks: Gave 9, Got 7
an RF modulator gives the device a channel.
In other words you plug the video feed from your DVR in to the modulator, and you set a channel number on the modulator.
Connect the modulator to one of the inputs on your distribution amp, and now tune your televisions to find the channel you set.
You will now be distributing your CCTV around your home
Old 01-07-2009, 2:12 PM   #5
Assured Advertiser
63,997, Level: 61
http://www.triax.co.uk/upload/ddu_installation.pdf This is for Triax DDU but has a nice diagram
RF Modulator's for CCTV Camera's shows a modulator and how to cannect just put your AMP where the connection to TV is shown
Old 08-07-2009, 4:07 PM   #6
6,740, Level: 19
Points: 6,740, Level: 19 Points: 6,740, Level: 19 Points: 6,740, Level: 19
hi there will this also allow the infra-red on the sky remotes to work in all rooms as well.
regards
chaddlad
Old 08-07-2009, 4:12 PM   #7
Assured Advertiser
63,997, Level: 61
should do if the amp is compatible
Old 08-07-2009, 6:48 PM   #8
2,454, Level: 11
look for the wording digital bypass. if so, then it'l support magic eyes
