cctv dvr - which ones?
Old 10-06-2009, 10:50 AM   #1
5,066, Level: 16
Points: 5,066, Level: 16 Points: 5,066, Level: 16 Points: 5,066, Level: 16
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
Thanks: Gave 95, Got 24
Hi all
i am looking for a cctv dvr (not a pc card) that will fit in my entertainment unit, which is max 39cm width
i need it to be able to motion capture, have networking so i can view it from my computers or when i am away from home
i don't need one with a dvd rw, these tend to make the dimensions to big for my unit anyway
i would have a max of 3 cameras so a 4 cam dvr would be fine, would prefer one with good fps per channel, so possibly 100fps unit
any advice on where to get one, and what makes to go for? there are so many out there but i don't know which ones are good or reliable, allot seem re-badged
budget about £200
thanks
Old 11-06-2009, 2:35 PM   #2
2,454, Level: 11
Points: 2,454, Level: 11 Points: 2,454, Level: 11 Points: 2,454, Level: 11
Thanks: Gave 9, Got 7
Re: cctv dvr - which ones?
heres one to consider on your budget
Labgear LAB3964 H.264 Digital Video Recorder: Amazon.co.uk: Electronics & Photo
Product Description
  • h.264 Baseline: selectable video quality levels
  • Hexaplex poeration - simultaneous record, live, playback, backup, control and remote access
  • Mixed operation windows - playback search for selected channel in the live monitoring mode
  • Mulit-level password
  • Search & by time or event (alarm, motion and video loss)
  • Recording quality can be configured into groups - better usage of hard drive
  • Support mouse and remote control
  • 5 network clients support
  • Multilingual support
Old 12-06-2009, 12:29 PM   #3
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Have a look at Xvision for a cheap basic DVR Xvision CCTV> Main Section > ANALOGUE CCTV > DVRs > Standard DVRs
http://www.x-vision.co.uk/product.php?xProd=25&xSec=47 Has the right dimensions
