| Another X10 problem, but this one has me stumped!!!
Ok so prior to today I have been using a X10 USB to RF transmitter, PC software and a TM13 transeiver, to switch on and off some lights around the house in 3 areas - in the living area two tabletop lamps on one appliance module, as well as a floor lamp a few metres away using its own appliance module( but set to same unit code as the table lamps, code 2). In the main bedroom two more appliance modules driving 2 lamps (sharing code 1) and finally a nother lamp in a guest bedroom on code 4. Using the supplied software I have been successful in switching on and off the lights as required.
So today my IR7243 arrives, which I bought to allow remote control capability of the lights with my Pronto TSU7000. As you can see the Pronto is a US unit, hence the need to use the IR7243 for control.
My problem is that today, having installed the IR7243 a few mins ago, all my lights work fine using the Pronto EXCEPT the third lamp in the living area. It refuses to switch on or off remotely. The only way to interact with the lamp is to physically turn it on or off via the footswitch. I changed over the appliance module thinking it may be faulty but no luck. I even assigned it a new code, but it doesnt want to talk to the rest of the X10 anymore. I noticed the lights work even with the TM13 disconnected, so I assume the IR7243 is a transceiver also?
So, any ideas? Ive also disconnected the computer interface as its no longer required, but before I did, that decided it didnt want to work either!
