Lighting - TV/Stereo/Wall/Shelf Ambiant Lighting for your setup!
Old 11-01-2006, 3:21 PM   #1
12,135, Level: 26
Points: 12,135, Level: 26 Points: 12,135, Level: 26 Points: 12,135, Level: 26
Thanks: Gave 5, Got 99
FOR THE REST OF THIS MONTH ALL NEON HOME LIGHTING KITS HAVE A FURTHER £5 DISCOUNT FROM THE LISTED FORUM PRICE!
[FONT="Comic Sans MS"]****** DISCOUNTED LIGHTING FOR YOUR VISUAL AND AUDIO SETUP ******
POWER BUY
Compliments of http://www.neon-lights.co.uk
[/FONT]
So you want to add some lights to your setup? Don't want to spend a fortune? Now you have the solution.
http://www.neon-lights.co.uk is now proud to offer DISCOUNTED items to members of AVFORUMS.
FOR THE REST OF SEPTEMBER 2007 ALL NEON HOME LIGHTING KITS HAVE AN ADITIONAL £5 OFF THE PRICE LISTED BELOW!
IMPORTANT NOTICE
Our kits come with "shielded inverters". They are in a metal case and designed to shield any interference inverters may cause, where as cheaper ones do not. We have spent a significant amount of time finding high quality mains adapters which carry a UK safety mark too, where as the cheaper kits do not. Our lights are produced to be brighter than the average bulb. We spend a lot of time, and put a lot of care into choosing the right parts to give the best effect, quality and extend the life of the product. All items are covered by a full 3 month warranty. Simply put, we are the best out there! (Check through this thread for all of the good reviews, images and feedback)
APOLLO LED LIGHTING KIT v2.0
For All Up to date information about the apollo lighting kit, see this post
Apollo LED Remote Control Ambient Lighting Kit! from neon-lights
HOME AUTOMATION
I now offer the full domia product range (x10) with harmony software. See Domia Home Automation | X10 | Harmony Suite Power buy for details.
Coming Soon
Remote control neon kits are only a couple of days away
PRODUCTS
If you want lights for behind your TV, speakers, shelving or to make your room glow I can help you out, if you have a special project and need some lighting that's different to any listed items, please ask. There is no problem producing custom items to suit your build.
SAFE!
These lights are CCFL (cold cathode) which means no matter how long you leave them running they are cold unlike normal light bulbs. Leave it on for an hour and grab hold of the tube to find it as cold as the moment you took it out of the box. This means you can put them places other lights just cant go. The light tubes are splash proof so can operate in a damp environment (plz note that the inverters are not splash proof).
CHOOSE YOUR OWN COLOURS!
Choose your own colours from the list below.
Blue
Green
Red
Ultra Violet (UV)
Yellow
White
Blue / Green / Red
Blue / Red
Purple
HOW DO I ORDER?
If you wish to purchase any products listed below at the forum special price, simply reply to this forum thread, and send me a Private Message. In your private message, state your full name, e-mail address, and the title of the item you wish to purchase. I will then send you an invoice via paypal, which can be paid using any debit/credit card, or if you have a paypal account you can pay using that. you do NOT require a paypal account to order. I also accept nochex, and direct bank payments.
ALL PRICES INCLUDE POSTAGE AND PACKING FEES - NO HIDDEN COSTS!
-=>> Apollo LED Ambient Lighting Kit (1 mil colours) - Various Prices
For the full breakdown of information about the apollo lighting kit, please see the following forum thread:
The Apollo lighting kit is our most advanced LED lighting kit. It boasts 1 million colour tubes, an IR Remote control which is complient with harmony, and other such remotes. You can blend your own colours using RGB from the remote, as well as choose from a selection of pre defined colour temperatures for white. There is also a timer function, dimmer option, save your fav colours to memory and recall at the touch of a button etc....
There are various size LED tubes available. 9", 15" and 24". You can also extend the cables from each tube if you need them longer.
This is the most advanced LED home lighting kit on the market for its price. Why spend thousands when you really shouldn't.
-=>> 12 inch Home Lighting Kit with power supply £22.50 (Does not include cable/switch)
The adapter included with this kit is suitable for keeping the lights running for long periods, (24x7). please note the inverter does get hot after an hour of use. The inverter is air cooled (heat is transfered to the air around the inverter) so it should not be put in a consealed area.
Ideal for people who want a simple product, with no hassel. Simply plug the lights in, and stick them in place using the provided pads.
You get:
2x 12" Cold Cathode Tubes
1x Inverter
1x Heavy Duty Adapter with a 5 meter lead
1x Sticky Pads (the kind that actually stick!)
-=>> Remote Control Upgrade for Neon Lighting Kits x1 - £25.98
This item allows you to take a single neon lighting kit, and add a remote on/off function.
The remote socket plugs directly into your power socket. The adapter from the lighting kit is then plugged into the remote socket.
want to make other devices remote? not a problem, you can use this remote on/off pack for any uk mains powered device!
Remote control spec:
* Battery: CR2032 (included)
* Frequency: 433.92MHz
* House Code: A-D
* Unit Code: 1-4
* Dimensions (mm): 57 x 29 x 12
Remote Socket Spec:
* Supply Voltage: 220/240V 50Hz
* Max. Load: 3000W
* House Code: A-H
* Unit Code: 1-8
* Dimensions (mm): 77 x 50 x 50
-=>> Remote Control Upgrade for Neon Lighting Kits x8 - £25.98
With this package, you can remotly control up to 8 neon home lighting kits! It will provide a remote on/off function.
Remote Socket Spec:
* Max. Load: 3000W
* House Code: A-H
* Unit Code: 1-8
Remote Control Spec:
* House Code: A-H
* Unit Code: 1-8
* Dimensions (mm): 75 x 45 x 9
This item is only provided with a single remote socket, but the remote is capable of managing 8. If you wish to purchase aditional sockets, you can do so here:
http://www.neon-lights.co.uk/index.p...&productId=109
-=>> 12 inch Home Lighting Kit with power supply / Cable / Switch - 27
You get:
1x Inverter
1x Heavy Duty Mains Adapter with 1.8 meter lead
1x 5 Meter extension cable with on/off switch
-=>> 12 inch Home Lighting Kit Neon Set - £9.25
This kit is for people who have their own adapters, and do not wish to purchase a cable with switch. It is simply the lights, and inverter with the correct connector for use with a 12v mains adapter.
It is recomended that you check if your adapter will be suitable before purchasing this item.
You get:
2x 12" Tubes
1x Inverter with 2.5mm DC Plug
1x Sticky Pads
-=>> 12 inch Home Lighting Kit with power supply / Cable / Switch - 4 tube - £49.50
A kit with 4 neon tubes for those larger screens or setups where you want to space our the sets of lights.
In each kit you get the following:
# 4x 12" extra bright cold cathode lights
# 2x 12v metal Inverter
# 1x 5 meter cable with table top lamp style switch
# 1x mains adapter
# 1x Y Splitter Cable
# 1x 5 Meter DC Extension Cable
# Sticky Pads & cable ties
-=>> 12 inch Home Lighting Kit with power supply - 4 tube - £45.50
# 1x mains adapter
-=>> 5 Meter DC Extension Lead - £4.00
If you need a bit more cable to run from your power supply to your lighting kit, use this 5 meter extension lead.
You get:
1x 5 meter extension lead
-=>> 5 Meter Lead with Switch - £5.25
Also available in 2 meter leads for a limited time only for £4
This cable is ideal for neon home lighting kits. You can plug this into any kit and you have a more suitable on/off switch.
you can put the switch into a more east to reach position.
You get approx 5m of cable, with the switch being 1m from the male end of the cable (the end nearer your inverter)
You get:
1x 5 meter lead + switch
-=>> Y Splitter - £5.00
Use this Y splitter to split the power lead into two. This allows you to run up to two home lighting kits from a single adapter.
Please note, that using the Y splitters may require you to upgrade your power supply. Please check this before purchase. We recomend
at least a 1000ma (1 amp) unregulated adapter to run two 12" lighting kits.
You get:
1x power Y splitter
-=>> 12" SPARE AND REPLACEMENT TUBES - £2.99
This is a single 12" tube. Ideal to replace broken tubes, or to simply change your colours around. Please check what type of inverter you have before purchasing single tubes to ensure you get the correct connectors.
You get:
1x 12" Cold Cathode Tube
There are many other available products, and styles of lighting available in the online store. Remember, if you are a member of this forum, you are entitled to discounts and special offers against nearly all store items. If you see something you would like to buy, simply Private message me and tell me which item you are interested in, and I will give you the special forum price.
Please reply to this thread if you would like more information or to place an order.
Old 19-01-2006, 12:46 AM   #2
4,315, Level: 15
Points: 4,315, Level: 15 Points: 4,315, Level: 15 Points: 4,315, Level: 15
Great item (12" Dual CCFL Home Kit in blue), thanks Alec. It looks much better than the Ikea LEDs - cooler if you know what I mean
Old 19-01-2006, 12:54 PM   #3
12,135, Level: 26
No problem Glad you like the effect
Old 23-01-2006, 4:10 PM   #4
robertsage's Avatar
6,185, Level: 18
Points: 6,185, Level: 18 Points: 6,185, Level: 18 Points: 6,185, Level: 18
Thanks: Gave 1, Got 0
Hi Noodleman,
I'd like to order the 12" Dual CCFL Home Kit - £16 in Blue please! I've sent you a PM.
Rob.
Old 13-02-2006, 4:05 PM   #5
ipbutler
Posts: n/a
Woo Hoo if your still doing these i'd like the 12" Dual CCFL Home Kit - £16 in blue please!!
Old 13-02-2006, 4:13 PM   #6
12,135, Level: 26
Hiya,
Yup they offers still stand!
Ive sent you both an invoice, Your order will be shipped the next working day.
Any problems, or questions, feel free to ask.
Old 13-02-2006, 8:47 PM   #7
Colonel Burton's Avatar
4,982, Level: 16
Points: 4,982, Level: 16 Points: 4,982, Level: 16 Points: 4,982, Level: 16
Thanks: Gave 40, Got 9
Hi, i would like to order the 12" Dual CCFL FULL Home Kit - £22 Blue please
Old 15-02-2006, 6:45 PM   #8
4,982, Level: 16
Order received this morning, great service great product cheers
Old 16-02-2006, 4:53 PM   #9
5,741, Level: 17
Points: 5,741, Level: 17 Points: 5,741, Level: 17 Points: 5,741, Level: 17
Hi, i would like to order the 12" Dual CCFL FULL Home Kit - £22 In Purple please.
Cheers,
Jon.
Old 24-02-2006, 5:02 AM   #10
2,896, Level: 12
Points: 2,896, Level: 12 Points: 2,896, Level: 12 Points: 2,896, Level: 12
Thanks: Gave 0, Got 3
Looks great will send PM
Old 26-02-2006, 6:53 PM   #11
UK_Strider
Posts: n/a
Thumbs up
Received my kits yesterday, setup them up last night and they look very nice! Thanks a lot Noodleman
Old 26-02-2006, 7:17 PM   #12
12,135, Level: 26
No problem. glad your happy with it
Old 03-03-2006, 11:48 AM   #13
4,060, Level: 15
Points: 4,060, Level: 15 Points: 4,060, Level: 15 Points: 4,060, Level: 15
Does the full kit come with 1 light or 2? Looks good.
Old 03-03-2006, 11:55 AM   #14
12,135, Level: 26
All lighting kits, come with 2 12" lights.
If you would like any more info, please feel free to ask.
Old 06-03-2006, 9:17 PM   #15
3,341, Level: 13
Points: 3,341, Level: 13 Points: 3,341, Level: 13 Points: 3,341, Level: 13
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 14, Got 18
Noodleman, is the 12" Dual CCFL FULL Home Kit likely to become available at any time soon?
Old 06-03-2006, 9:25 PM   #16
12,135, Level: 26
I am in the process of chaning the cable/switch that is used in this kit which is why they are currently not available.
I have finalised a design with a company and they should be back in stock within 2 weeks.
The design is a better quality cable than the previous ones, so should be worth the wait.
If you wish, you can still order the kit, on the understanding that the cable is out of stock. I can send you everything else, and send you the cable once it is in stock.
Old 12-03-2006, 9:28 AM   #17
4,982, Level: 16
Hi Noodleman, could i please order a replacement tube for the order above as i broke a tube yesterday cheers
Old 15-03-2006, 5:46 PM   #18
12,135, Level: 26
the FULL hom kits are now back in stock.
The design of the cable has changed to make them easier to install and conceal (thinner cable).
The power connectors are now a higher quality too.
Old 15-03-2006, 7:32 PM   #19
3,341, Level: 13
Activity: 0.7%
In that case, I'll have a Full Home Kit in Blue please.
I've PM'ed you my details.
Old 18-03-2006, 4:03 PM   #20
dragonfly's Avatar
7,583, Level: 20
Points: 7,583, Level: 20 Points: 7,583, Level: 20 Points: 7,583, Level: 20
Thanks: Gave 3, Got 3
Noodleman,
I would like to order 12" Dual CCFL full home kit @ £22 in purple please.
I have a paypal account.
Regards.
Old 18-03-2006, 4:09 PM   #21
12,135, Level: 26
No problem. I have sent you a PM with details.
Old 20-03-2006, 8:53 PM   #22
3,341, Level: 13
Activity: 0.7%
Just got my 'full home kit' and set it up. I have to say I think it looks great. Thanks Noodleman.
Old 20-03-2006, 8:54 PM   #23
12,135, Level: 26
Hi Pete,
thanks for letting me know it arrived safe
Any chance of some pics if you have some time?
Old 20-03-2006, 10:47 PM   #24
4,085, Level: 15
Points: 4,085, Level: 15 Points: 4,085, Level: 15 Points: 4,085, Level: 15
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 31, Got 11
can you connect these guys up in series.
I have an approx 75*45 inch screen.....
Old 20-03-2006, 10:50 PM   #25
12,135, Level: 26
Unfortunatly, not in series.
However you can hook them up in parallel using a Y Splitter cable to the inverters.
These cables are custom made, to suit the dimensions you have to work with. Currently working on a design for a 1.8m x 2.1m wall design.
Old 20-03-2006, 11:01 PM   #26
4,085, Level: 15
Activity: 2.0%
I'd be very interested in a design to suit my needs.
The actual screen size is 193.8cm * 116.3cm, in order not to see the bulbs (and just have a nice glow), I'd need to mount them say 20cm from inside each outer edge.
That would make the lighting area 154*76 cm. To round it, it looks like I'd need 2 bulbs for each side, and 5 for each length. Would that be too bright?
How many kits/Y splitters would I need?
Old 21-03-2006, 5:29 PM   #27
3,341, Level: 13
Activity: 0.7%
Originally Posted by Noodleman
Hi Pete,
Try this one for starters (apologies for poor image quality)...
Old 21-03-2006, 5:47 PM   #28
12,135, Level: 26
I would recomend that you put 1 12" tube at each side (left / right) and 3 tubes across the top/bottom.
You may be able to reduce the number of tubes required if you could place the tubes central.
Using the method i mentioned above, you would use 8 12" Tubes, and 4 Inverters.
It should provide plenty light. You may even be able to reduce the tubes across the top/bottm to 2 tubes, however i cant guarentee how this would look.
8 tubes *SHOULD* be able to be powered from 1 socket, using 1 custom made splitter cable. However, i will need to check the power requirements in more detail before i can confirm if 8 tubes will be fine from a single adapter.
Old 21-03-2006, 6:06 PM   #29
4,085, Level: 15
Activity: 2.0%
ok cheers.
How thick are the tubes/blocks that they are mounted in?
thanks again
Old 21-03-2006, 6:09 PM   #30
12,135, Level: 26
The tubes are about 8mm, but the blocks on the ends are about 10mm (1cm)
so for mounting, you need at least 1cm of space
