Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Home Automation, Lighting and Climate Control
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Old 18-02-2009, 8:05 PM   #1 (permalink)
Wanted: X10 whole-house filter
I'm having some work done on the consumer units in my house, and want to have an X10 filter fitted at the same time. I'm looking for the 200A unit like either of the ones below, not the FD10 DIN rail style or the FM10U plug-in filters.
Nobody seems to stock them in the UK anymore, but before ordering one in from California at exhorbitant postage rates I thought I'd ask here to see if anyone knows any stockists in the UK ?
dmb0058 is offline   Reply With Quote
Old 18-02-2009, 8:15 PM   #2 (permalink)
Thanks: Gave 1, Got 18
Re: Wanted: X10 whole-house filter
Can I ask why you're fitting one?
silver12 is offline   Reply With Quote
Old 18-02-2009, 8:18 PM   #3 (permalink)
http://www.letsautomate.com/10218.cfm?
Old 19-02-2009, 12:56 PM   #4 (permalink)
Great, thanks. Don't know how I missed that one, but got one on order from there now.
I'm fitting it because I'm getting random sequences of X10 commands every so often. A typical sequence would be A1 Off, A2 off, A3 off, right down to A16 off - more likely to be alien transmissions than random noise I reckon ! I also changed the house code a while back to see if that would work, within a day had a sixteen unit D1-D16 Off sequence ... on the new house code. I also occasionally get other odd events such as lamps coming on in the middle of the night or random switch offs of individual units. These don't correlate with any other electrical activity in the house, e.g. other lights or devices being switched on or off, either manually or automatically.
I've taken every device that I have that's capable of sending X10 off my setup (e.g. CM11, alarm system, TM13), but I'm still getting these spurious commands coming through. I still have a couple of things to sort out, e.g. I have a bunch of servers in the attic running off an unfiltered UPS, and am waiting for a FM10U filter to close these off.
One main reason for going ahead is that I'm about to have two consumer units merged into one and a few new sockets fitted. I figure that it'll be cheaper to buy a whole-house filter, have it fitted at the same time as the other work and then find that it wasn't an external problem after all, compared to later deciding that it must be an external problem and having to call out the sparky for a second job.
Old 19-02-2009, 4:21 PM   #5 (permalink)
I've ordered from them before and they're pretty decent - always seem to take a while to reply to emails but that seems to be the norm. these days.
Do you use X10 for all your automation? I wasn't really aware it was still widely supported.
Old 19-02-2009, 4:59 PM   #6 (permalink)
Yep, use it for lots of stuff. Usual remote operation of lights around the house, both plug-in lamps and landing/porch/shed lighting. Our security system can also send X10 commands when sensors are tripped, and can run multiple scedules per device.
Control-wise we use RF remotes around the house, and either web (linux server running Domus.link/Apache/Heyu to a CM11U), DTMF or SMS commands (the security system has PSTN and GSM to X10 capability) to query status or switch stuff when we're away. The server sends X10 to turn devices on and off as required, and also receives X10 events (e.g. motion sensor alerts) to do things like record off IP cameras, send SMS alerts, email notifications etc.
There's loads of X10 gear still in production, both the original style X10 company stuff and later versions like the Domia kit. I guess it just refuses to die !
edit: meant Domia, not Domotica, but googling Domotica threw up this site: http://www.bwired.nl. This guy is an automation fanatic !!!
Old 25-02-2009, 1:11 AM   #7 (permalink)
Can I ask what made you steer away from the FD10 installation?
Signature deleted by Admin
homeautonutter is offline   Reply With Quote
Old 03-03-2009, 8:38 PM   #8 (permalink)
I didn't go for the FD10 because it would have been wired between the main isolator switch and the consumer unit ahead of the whole-house mains supply. The incoming supply is physically connected through the FD10, whereas the TF678 filter is inductive so not actually connected to the main phase.
While it would be fine for an individual spur in a radially wired house, I figured that sitting it ahead of the whole house circuit makes the FD10 a 63A fuse ! I'm not confident that I won't want to draw over 63A across the ring main/lighting circuits some time in the future so went for the 200A filter.
Old 15-03-2009, 9:17 AM   #9 (permalink)
Thanks: Gave 1, Got 17
Have you checked that its not some other electrical device causing this? I had a strange problem where a laptop PSU was causing some lamps to come on at random times, but weirdly it was always the same lamps which had let me to believe it was an X10 device doing it. But unplugging the laptop PSU caused the problem to go away.
Ben
benwillcox is offline   Reply With Quote
filter, wanted, wholehouse, x10
Copyright © 2000-2010 M2N E. & O. E.
