Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Home Automation, Lighting and Climate Control
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Title deleted dnlmahon Subwoofers and Tactile Transducers 0 10-02-2009 10:07 PM
X10 Remote Control Danno72 Home Automation, Lighting and Climate Control 0 10-02-2009 9:27 PM
Low Signal Strenth atann Sky HD 1 10-02-2009 6:20 PM
Convert AVCHD to what? with what? (for editing on low powered PC) mmace Camcorders and Video Editing 3 10-02-2009 1:58 PM
Old 11-02-2009, 8:31 AM   #1 (permalink)
Thanks: Gave 7, Got 16
X10 low energy
Can't seem to find a definitive answer to this other than "no" so here goes. I have an LW10U dimmer which I simply use to on/off 2 60W regular bulbs in my living room. I'd like to change these to low energy bulbs but can't because the switch needs a minimum load and has issues with low energy lighting. My PC switches on these lights when we are out (alarm set) automatically. The LW10U replaced 2 switches which brought on each light independently. One of the lights has a 2nd cord switch which we don't use.
So - is there any way I can get low energy bulbs into this setup. Happy to change the switch or add extra stuff (I have an LM15 bayonet lamp module handy and appliance/lamp modules). Happy to modify something if necessary. At the very least would simply replacing 1 bulb with a low energy work (as total load would still be greater than 60W).
Thanks for any help.
steford is offline   Reply With Quote
Old 11-02-2009, 9:04 AM   #2 (permalink)
Thanks: Gave 26, Got 133
Re: X10 low energy
You cannot standard low energy lights with dimmers - the ballast in the low energy lamp cannot be dimmed this way. Even with the dimmer set to 100% still causes problems for the ballast as the dimmer output is not a clean sine wave. You run the risk of blowing the lamp and/or dimmer. However there are now dimmable low energy lamps from Megaman and Varilight that will be ok providing you keep the total load above the minimum required by your x10 dimmer. These dimmable low energy lamps are much more expensive than standard units and ideally need to be started at 100% before being dimmed down. With some dimmers they are not very linear when dimmed but at least they will not damage the dimmer or lamp.
neilball is offline   Reply With Quote
Old 11-02-2009, 2:01 PM   #3 (permalink)
Re: X10 low energy
So as it stands I could add a single Megaman into the circuit - leaving 1 60W original bulb in there to keep the load up?
No other X10 switches (non-dimmable) or devices allowing me to use 2 regular low energy bulbs?
Thanks.
Old 11-02-2009, 4:59 PM   #4 (permalink)
Re: X10 low energy
There are X10 relay/appliance modules which should be capable of giving switched control of standard low energy lamps but these are din-rail modules so not direct replacements for the faceplate dimmer you have just now. Is your wiring in any way accessible to allow the use of an appliance module thereby letting you replace the switch plate dimmer with a conventional momentary switches?
Old 11-02-2009, 9:16 PM   #5 (permalink)
Re: X10 low energy
When you say accessible where do you mean? Other than at the switch, the 2nd switch or in the celeing I'm not sure. I've never been too clued up on the din rail modules as to what they can do/where they go.
EDIT: OK I've had a quick look round. If I understand this correctly I could stick an AD10 (din rail switch) behind a regular switch (removing the dimmer entirely) or replace the cord switch with one. This would provide X10 switching on the current 2-way circuit and if it is simpy an extra controlable on/off would do exactly what I need. Is that right?
Old 11-02-2009, 10:20 PM   #6 (permalink)
Re: X10 low energy
I'm with @neilball - Using an X10 appliance module will work with fluorescents and low energy bulbs. You will lose the ability to dim, but it sounds like that isnt needed so an AM12 or the Domia 10 (not lite) equivalent will do the trick.
NicB is offline   Reply With Quote
Old 12-02-2009, 3:43 PM   #7 (permalink)
Re: X10 low energy
Thanks for that - getting one of those into wall space might be hard though!
Can the DIN Rail stuff be installed in there (it's smaller according to the spec I can see)?
Thanks.
Old 12-02-2009, 8:28 PM   #8 (permalink)
Re: X10 low energy
Sorry, I should have paid more attention - There is an AW10U whcih is the appliance version of the LW10U. That should be a drop in replacement.
Or you could go with an AW12 micromodule and install a push-to-make switch. A little more complex and more costly, but gives you a different aesthetic cos you can choose your own switch.
Old 13-02-2009, 11:51 AM   #9 (permalink)
Re: X10 low energy
I believe the AW10 needs a neutral. I'm thinking I could stick any compatible X10 switcher behind my corded switch (not in use). As this controls 1 of the main lights independently it would be ideal.
Old 03-03-2009, 12:36 PM   #10 (permalink)
Re: X10 low energy
Ran this by Lets Automate and the claim there's nothing that can help me. Any further thoughts?
Old 15-03-2009, 9:25 AM   #11 (permalink)
Thanks: Gave 1, Got 17
Re: X10 low energy
One solution is to replace your X10 lamp module with an X10 appliance module. However these make a big CLICK due to the relay, so can be annoying to listen to!
BUT, I have replaced quite a lot of my X10 controlled lamps that were originally incandescents, with CFL replacements. What I found was that they can work ok, providing you get the correct brand of lamp! I have a couple of Megaman 2000 11 watt bog standard CFLs controlled by a couple of X10 plugin lamp modules, with no problems at all (obviously don't try and dim them, it doesn't work). However some other lamps I tried first flickered badly when in the 'off' state.
I would suggest getting a couple of different types and just give them a try.
Ben
benwillcox is offline   Reply With Quote
SeanT (28-03-2009)
Old 16-03-2009, 12:41 PM   #12 (permalink)
Re: X10 low energy
Unfortunately it's not a lamp module - it's a wall switch and apparently there's nothing out there that can help. I do have some appliance modules handy so I could stick a few lamps on them of course but wanted to stick with the current setup. The idea of trying the megaman bulbs is a good one but they are expensive if they don't work and Megaman have told me they don't recommend the x10 dimmer switch.
My latest thinking is to go back to 2 standard switches and replace the currently unused cord switch with the x10. This would at least allow me to replace 1 bulb with a low energy alternative and switch one on/off for security whilst costing me nothing.
Not ideal but there seems little choice.
Old 16-03-2009, 12:50 PM   #13 (permalink)
Re: X10 low energy
Ok but internally it's probably the same technology, I have used LD11 DIN modules and plugin lamp modules with success. Have you actually tried any low energy lamps on it? It doesn't do any harm, it'll either work, or it won't. The megaman lamps I use are just the cheapo standard 99p (or whatever) jobbies, not the dimmable ones.
Ben
Old 16-03-2009, 1:27 PM   #14 (permalink)
Re: X10 low energy
Ben
That's interesting.
Yes I tried low energy some years ago and got the flickering - from what I've read this can cause overheating and burning at the switch.
Probably worth picking up some Megamans at that price then to see how they go in the current setup - there is a minimum wattage required though (like the lamp modules) and 2 of those will be way under.
Old 20-03-2009, 12:24 PM   #15 (permalink)
Re: X10 low energy
Couldn't source any Megamans locally so have gone with the current setup with a 60W standard bulb and an 11W low energy and leaving the switch as is to save hassle. Everything I've read and been told points to not going below 60W with the LW10U switch.
energy, low, x10
Copyright © 2000-2010 M2N E. & O. E.
