Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Home Automation, Lighting and Climate Control
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Rotel Power Amp Hum / Buzz hoppaz Audio Processors and Power Amps 5 21-09-2009 5:22 AM
How to deliver 12V power over Cat 5 to Rako controls Techpigmy Home Automation, Lighting and Climate Control 3 17-09-2008 9:21 PM
Ikea "Koppla" remote-control socket dimmer with timer brendan_dj Home Automation, Lighting and Climate Control 3 26-11-2006 9:22 PM
Dimmer Switch, that doesn't buzz? image165 Home Automation, Lighting and Climate Control 15 29-08-2005 7:07 PM
Old 01-10-2008, 1:06 PM   #1 (permalink)
owain_thomas's Avatar
Thanks: Gave 63, Got 55
rako dimmer causing power socket to buzz when microwave on?
We are just going through a bit of a revamp of our house and seem to have come upon a bit of a weird problem, when the kitchen lights (12v halogen DLs) are dimmed (using a rako in-ceiling dimmer) the socket that the microwave is plugged into buzzes quite noticeably, but only if the microwave is on.
I've had rako kit for a couple of years now and not had any issues like this, any ideas why it may be happening?
flickr
HC - Rotel RSP-1068 Processor, Mac Mini running Plex, Arcam A90, Totem Arro Speakers
TV - Panasonic TH42PHD8 with Lumagen HDP
owain_thomas is offline   Reply With Quote
Old 01-10-2008, 9:28 PM   #2 (permalink)
vex
Assured Advertiser
Location: Herts today, Essex tomorrow, Friday THE WORLD har har harrrrrr.
Thanks: Gave 11, Got 190
Re: rako dimmer causing power socket to buzz when microwave on?
That is 'buzz'ar (excuse the pun)
I have copied this to someone to see if he has any idea.
HTH
V.
Be careful out there forumites - 89% of statistics are made up.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
vex is offline   Reply With Quote
owain_thomas (01-10-2008)
Old 01-10-2008, 9:31 PM   #3 (permalink)
thanks vex, look forward to hearing any suggestions
flickr
Old 02-10-2008, 8:13 AM   #4 (permalink)
Could you confirm the 'buzz' is coming from the socket the microwave is plugged into, as this does seem really quite bizare. There is nothing inside a socket (or plug) that should buzz, the only thing that could make a noise is if a terminal is loosly clamped onto a wire.
Regards
Paul
Paul Wafer - Rako Controls Ltd - www.rakocontrols.com
Pioneer PDP428XD - Onkyo 806 Receiver - SKYHD - AppleTV160 - Sony PS3 - Nintendo Wii - RTI T2C - Speakercraft MZC66 MODE System - Rako Whole House Lighting System
pwafer is offline   Reply With Quote
Old 02-10-2008, 9:32 AM   #5 (permalink)
hi Paul,
thanks for the response, I was a bit surprised as well, at first I thought it must be the microwave itself but on closer inspection it's definitely the socket.
flickr
Old 02-10-2008, 4:39 PM   #6 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 97, Got 1,360
OWain where are the lights in the kitchen wired from? Are they on a lighting circuit? Which Rako unit controls them?
hornydragon is offline   Reply With Quote
Old 02-10-2008, 7:21 PM   #7 (permalink)
hi HD,
the kitchen lights are wired on a lighting circuit AFAIK, the electrician who did the work has not been around for a couple of days so I haven't been able to check with him but the plan was always for the new build part to all be on its own circuits. the lights are controlled with a standard 500W in ceiling dimmer.
flickr
buzz, causing, dimmer, microwave, power, rako, socket
Copyright © 2000-2010 M2N E. & O. E.
