Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Home Automation, Lighting and Climate Control
Latest AVForums Movie Reviews
Zombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray Review
Clash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray Review
Old 04-04-2007, 1:14 PM   #1 (permalink)
Ricky Prentice
Posts: n/a
Unhappy (cheap!) Home security recommendations?
Ive just moved into a new house and need to buy some home security does anyone know of any self install systems for around £300.00 grateful for any ideas as every were i look is too expensive!! i want cameras and it would be good to get alerts.
Old 05-04-2007, 11:21 AM   #2 (permalink)
Re: (cheap!) Home security recommendations?
If you have broadband then my husband bought a kit a couple weeks ago, which we think is great as you can access it remotely and i can control it from my mobile too. I think it's called X1000 from myhome. We have put power controllers to eliminate our tv standby - gotta think green! and have temp sensors keepin our fish healthy so was ideal system for us. Oh cameras are ip based and can be viewed live from some mobiles - mine does hubbies doesn't so can see what is happening if a device goes off. £250 with the extra bits ours cost. http://www.myhome247.co.uk
JJ London is offline   Reply With Quote
Ricky Prentice (11-04-2007)
Old 05-04-2007, 11:45 AM   #3 (permalink)
Thanks: Gave 14, Got 31
Don’t waste your money on ‘cheap’ security, it is a complete false economy and offers little or no protection whatsoever. For £300 you could have a professional company install a reasonable ‘bell only’ system that will perform much better than any of DIY systems that you can readily buy. Obviously if you stretch your budget a little you can improve on this, but never skimp on security. You could have your intruder alarm specialist install a voice and text dialler (approximately £100-£150) that can send you a text message in the event of an alarm, if you don’t fancy the ongoing costs associated with a fully monitored system. On a side note, speaking from a professional point of view, do not install any alarm system that relies on a broadband connection for alarm monitoring, they are extremely unreliable and often fail to report an event. If you have a limited budget you are much better upgrading locks, adding security lighting etc before installing a DIY alarm. Almost every DIY alarm installation I have seen (and many ‘professional’ installations for that matter), can be silenced/disabled within a matter of seconds by an intruder who has a vague understanding of how an alarm works.
ZippyCat is offline   Reply With Quote
Old 05-04-2007, 11:53 AM   #4 (permalink)
Oh, I forgot to add a comment regarding CCTV.
Unless you have a budget in excess of £1000 for CCTV, then don’t bother. Cameras and associated ancillary equipment at the budget end of the market will not provide sufficient evidence to be used in any criminal prosecution. You would be better spending your money on other security measures.
Regards,
ZippyCat
Old 06-04-2007, 12:26 PM   #5 (permalink)
Thanks: Gave 1, Got 7
Its always worth having a camera or two outside to deter the casual thief or kids etc.
Its considerably more likely to be hit by an amateur or petty thief than a pro, especially in the less rich areas.
Sprout Crumble is offline   Reply With Quote
Old 06-04-2007, 2:44 PM   #6 (permalink)
The point I was trying to make is that you are better off investing in a couple of decent measures of security than lots of poor to average measures. If you were after the deterrent factor, it would be better to install an empty full sized camera housing (e.g. Dennard D2010) than installing a budget camera. With regards to the alarm side of things, it always makes me laugh when I see those Yale or Response systems that people buy from B&Q or Home Base that plug directly into the phone line. It doesn’t that a pro to disable one of those; all the intruder would need to do is head towards the source of the sound (the main panel), and unplug the thing from the phone line, as you would do with a normal telephone. Even the most idiotic intruder would be able to manage that one! In my opinion the best measure of security for a nighttime deterrent is to ensure there is a good level of lighting surrounding the building; criminals do not like to be seen.
Old 06-04-2007, 2:49 PM   #7 (permalink)
Certainly agree with the lights and the big dummy cameras. If you can't afford a decent security setup then make it look like you can.
Old 19-04-2007, 8:50 PM   #8 (permalink)
jagdeepp's Avatar
Thanks: Gave 195, Got 115
Regards,
ZippyCat
Now, i entirely disagree with that assertion. Its absolutely rubbish. I'm a criminal defense lawyer and have experience of some very decent cctv cameras. You'll be surprised as to how poor a quality you can end up with even on the bigger cameras. The primary point is this, even if the camera were budget you've got a higher chance of securing a conviction if the person can be identified with grainy footage by specific clothing worn by the offfender or by a glimpse of his face. Usually any reference to cctv at site is enough for an offender to panic and 1 in 4 will admit on a full facts basis!
On the flip side however even if u have the highest quality of camera in the world it wont make a blinding bit of difference if it covers your doorway but not your garage which he climbs over. Alternatively, your high quality camera still won't help if you capture footage of someone but he's wearing a common hoodie disguising his face.
The long and short of it is, cheap or expensive there are benefits to any kind of security! Site of a visible camera even dummy is enough to put off most offenders. Remember most offenders are opportunistic. They have drug habits in most cases to feed and will often target an 'easy job' than a property which is 'hot'.
hope that helps
My Set up: Sony Panny PT-AX100 HD Projector, 2.2 metre HCSV electric screen, Arcam AVR350 amp, HTPC's with 1 TB, Monitor Audio RS6 5.0, BK Monolith, Nintendo Wii, Snazio 1310, Xbox 360,
My Home Cinema Lounge & Home makeover
jagdeepp is offline   Reply With Quote
Old 20-04-2007, 8:21 AM   #9 (permalink)
hope that helps
Well speaking from a professional point of view I stand by my opinion. For a start it has nothing to do with the ‘size of the camera’ as you put it, but the quality of the components inside and the application of the system that makes a difference. I would agree with you that most professional CCTV cameras in the UK are still not setup correctly and are not used to the maximum potential. Even the highest quality camera will still yield poor results if not setup correctly, so there also needs to be a degree of experience when installing a system. Also as a lawyer you will be familiar with the submission of evidence guidelines that set the parameters for evidence suitable for admission in court. Unless you purchase professional quality equipment you will not meet all the parameters set out in such documents i.e. time date stamp and DPA. As a lawyer you will only ever see images from cameras that have actually captured evidence, not a camera that has missed such events. I can categorically state that poor quality CCTV equipment or CCTV equipment not used in the correct way will result in an unusable image; this unusable image will not make its way to any prosecution case (in most cases the police will not even take recordings offsite). The best security measures that home owners can take are measures that act as deterrents, the main one being a decent level of perimeter lighting, then good quality windows, doors and locks, and finally a monitored alarm. A home owner would be prudent to invest in upgrading these security measures first than squandering £300 on a ‘B&Q CCTV special’. If you read further down I have also stated that it would be better to invest in an empty full sized camera housing than to spend the same amount on a ‘working’ camera. Reading between the lines I feel you agree with this last statement when you mention dummy cameras.
Old 21-04-2007, 11:12 AM   #10 (permalink)
Thanks: Gave 0, Got 3
Hi, not posted before but i feel i should on this matter...
I have a cheap black and white camera from Argos i believe. It's pointed at my navara outside the house. It's got excellent visiblity at night and during the day. Plus sound (although the only thing you usually hear is wind!!!).
It's linked into the video player and i just set it to record every night. Though any recording machine can be used.
I found a key scratch on it one morning so i looked back on video and found the little ****. Needless to say he didnt do it again.
The whole point is there are cheaper alternatives that work well and its also a good deterant (too most people) due to the bright blue LED it has on the front.
As for alarms i DIY'ed our burglar alarm bought all the bits from Screwfix and wired it in myself. With all the cable hidden in the walls, etc it would take some time to silence! (i hope)
Hello everyone
Samsung LE46F71B LCD | Jap PS3 | Cambridge Audio DVD55 | Yamaha RX-V357 Receiver | Yamaha AX-392 Amp | TDL Floor Standers| Mission Centre | Eltax Rears
Mivan is offline   Reply With Quote
Old 05-09-2007, 2:03 PM   #11 (permalink)
Thanks: Gave 9, Got 0
Regards,
ZippyCat
Sorry to chip in sooooo late on this one. As a copper I'd rather people had "some" security than none. I have just seen 4 burglars sucessfully convicted after being identified by a crappo PIII system with a web cam and motion detection software. They clocked the camera and ripped it out, but left the server, which was in plain sight. Victim already had a disk of footage waiting for me when I turned up to report it!
You don't need to spend a thousand pounds. Tuck your server away somewhere where the burglar wont find it (ie loft/broom cupboard) and you will be fine. With secet/hidden cameras the burglar might stare right at the camera and give you a perfect image to take to court.
Some is ALWAYS better than none, and, of course, spend wisely where the money is best spent. Window locks, motion sensor lights, trimming bushes etc etc are alo great ways to minimise your chances of getting screwed.
I say we take off and nuke the entire site from orbit.....it's the only way to be sure.
Colonial Marine is offline   Reply With Quote
Old 12-09-2007, 8:58 PM   #12 (permalink)
Thanks: Gave 3, Got 2
I too want to pipe up about this, i installed 'crappy diy'er' alarm in my old house, one day i was burgled it only had one sensor fitted in the hallway, but you could tell by the way they had left in a hasty manner, ie no further than the hallway the alarm had triggered and had scared them off.. For the 50quid it cost me im happy.
And now im happy to install a better one this time, covering all windows etc.
Now if i had alot of money id pay someone but i haven't so im doing it myself.
I took some tips from the police, don't leave any tools or things lying around in the garden, apparently alot of them use these tools in case what they have isn't enough (they use a spade of mine to get in my back window).
And do fit a camera, any sorts in good view also post a warning on vulnerable windows in small text "warning, cameras in use, and will be used in prosecution of any traspassers" etc, let them know you're expecting them!
Its always good practice to remove the back door key etc when you are out, again my thieves had to leave hastily the way they got in, as all doors were locked with keys strategically hidden, good luck.
moogen is offline   Reply With Quote
Old 26-09-2007, 9:29 PM   #13 (permalink)
blicky_1's Avatar
Thanks: Gave 357, Got 112
Zippy as a GM of a professional installation company I totaly agree with you just a shame everyone does not see the things we do (DIY installs, cheap equipment, and ADT) over 50% of our work is taking out DIY systems that are less than 2 years old! usually after the warranty runs out....
If I had a pound for the amount of women I have had in tears during a survey after a break in I would be retired Most of them either had a DIY system the husband installed on the cheap and it did not work or a system that was 20+ years old! and they lost items that could not be replaced.....
Bottom line is professional systems WORK if they don't sue the company that installed it. Best to get an NSi (NACOSS) approved contractor and have it on a contract to ensure everything is checked and working.
Hitachi 42PD7200|Optoma HD70|100" HCSV Screen|Onkyo TX-SR705E|B&W DM603s1 Fronts|B&W CC6s1 Centre|B&W DM601s1 Rears|Yamaha SW90 Sub|Sky HD|Dreambox 7020si + Motorised 88cm Triax Dish 53.0°E-30.0°W|Xbox|Xbox 360|PS3|Wii|PSP|DSi|Ipod Touch 32GB|Harmony One|Nikon D70s|Sony HC35|WHS|MBP
blicky_1 is offline   Reply With Quote
Old 27-09-2007, 5:27 PM   #14 (permalink)
Don’t get me started on ADT; I recently had to advise their technical department that a single dual technology detector does not constitute as a confirmed alarm!
Old 27-09-2007, 6:24 PM   #15 (permalink)
Thanks: Gave 187, Got 241
Just out of interest, which professional installer?
www.flickr.com/photos/simonr_uk
Photo kit: Nikon D300S (Yay! finally got one), Nikon 16-85 VR, Nikon 35mm F1.8 AF-S, Nikon 70-300 VR, Tokina 12-24 F4 II, SB-600
Strobe is offline   Reply With Quote
cheap, home, recommendations, security
Copyright © 2000-2010 M2N E. & O. E.
