3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Home Automation, Lighting and Climate Control
Latest AVForums Movie Reviews
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray Review
Julie & Julia Blu-ray ReviewLast Action Hero Blu-ray ReviewBlack Dynamite Blu-ray ReviewProphecy - Music From The Motion Picture CD ReviewHarry Potter And The Chamber Of Secrets Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Modern Warfare 2 Special Ops: Play & Help legend_of_chaos Call of Duty (COD) PS3 135 08-01-2010 1:07 PM
Budget Monitor Advice rjtyrell Monitors, Webcams and External Video Devices 3 30-11-2009 11:46 PM
Install advice please - Berkshire bullett Custom Installations and Installers 3 18-11-2009 9:02 PM
Advice on choosing my first head unit cseal11 In Car Entertainment (ICE) 6 18-11-2009 5:41 PM
Xmas present advice please simonoaks Nokia Mobile Phone Discussions 0 18-11-2009 10:03 AM
Old 18-11-2009, 10:32 AM   #1 (permalink)
Thanks: Gave 1, Got 0
X10 controllers...help and advice needed please!
I’m quite interested in getting some X10 gear for my house, and have done a fair bit of reading up on available kit, etc, from various sites. However, I can’t seem to find the right controller/master/brain for the system as I’ve found conflicting information.
Can anyone recommend a system that will work with the computer switched off, yet hooks into my home LAN and allows local and/or remote control via the web or my iPhone? I’d like to be able to turn lights on/off remotely as well as have some lights on timers, etc, but my wife goes nuts about having a computer on all the time...
Thanks!
SysRq is offline   Reply With Quote
Old 18-11-2009, 12:41 PM   #2 (permalink)
Thanks: Gave 175, Got 139
Re: X10 controllers...help and advice needed please!
Hi, you need an x10 gateway
Something like this:
http://www.webio.us/doc/KE_WebIO_datasheet_v1.3.pdf
I have not used one myself so cannot reccomend any particular one.
For timed events a CM15 or CM11
Here's one I found that does it all:
EZSrve INSTEON/X10 Home Automation Gateway (EZSrve 5010L)
Both of the above are for the US. Maybe you can find a UK equívalent. The CM15 is Ok for the EU.
edited to add:
Found one that appears to do what you want and is for sale on a UK website
HomeVision Home Automation Controller
Mark
AV photos here
m4rky_m4rk is offline   Reply With Quote
SysRq (18-11-2009)
Old 18-11-2009, 1:38 PM   #3 (permalink)
That's brilliant - thanks very much!
advice, controllers, controllershelp, needed, x10
Copyright © 2000-2010 M2N E. & O. E.
