Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting and Climate Control
Latest AVForums Movie Reviews
Music Man, The Blu-ray ReviewUgly Truth, The Blu-ray ReviewEmpire Of The Ants - Original Motion Picture Soundtrack CD ReviewThe Toolbox Murders Blu-ray ReviewDungeons & Dragons: Wrath of the Dragon God Blu-ray Review
The Book of Eli - Original Motion Picture Soundtrack CD ReviewInvention of Lying, The Blu-ray ReviewSmokin' Aces 2: Assassins' Ball Blu-ray ReviewDorian Gray Blu-ray ReviewL'armée du crime Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Bravia 40W3000 Error 13 standby flashes dave_em Sony Owners' Forum 1 08-08-2009 1:10 PM
41 Flash Games for Archos - 41 jeux de Flash pour Archos TeddyM Archos Owners' Forum 0 03-07-2009 6:39 AM
Daewoo DT-4280NH - Standby light flashes red and green, and makes a clicking sound. Electronics Way Plasma Televisions 1 02-07-2009 9:20 AM
HXD890 Flashing Green Screen Glynn DVD and Blu-ray Recorders and Media 1 01-07-2009 7:48 PM
Cable light on Modem keeps flashing pleo2005 Virgin Media Blueyonder 11 01-07-2009 4:33 PM
Old 03-07-2009, 8:33 PM   #1 (permalink)
flashing lutron
hi I have a double gang lutron rania but it has a fault with it and could do with some help
the right hand side flashes all leds fast when you go to use it and no lights come on the when left for a little time it still flashes but slower is this a fault code
thanks col
colw1 is offline   Reply With Quote
Old 04-07-2009, 12:49 PM   #2 (permalink)
Thanks: Gave 20, Got 27
Re: flashing lutron
Has the unit worked previously or is it a new install? I have seen this when they are installed incorrectly and overloaded, so it could be that one of you transformers has an internal short circuit.
Check your lamp ratings too, make sure you are meeting the minimum load for the dimmer.
A man's got to know his limitations...
dalethecaptain is offline   Reply With Quote
Old 05-07-2009, 6:44 PM   #3 (permalink)
vex
Assured Advertiser
Location: Herts today, Essex tomorrow, Friday THE WORLD har har harrrrrr.
Thanks: Gave 11, Got 189
Re: flashing lutron
Are you using low voltage lighting, ie via transformers to step down to 12v?
This is a common problem as the dimmers are set up for standard incandesant lights. There is a button sequence that switches the rania's to trailing edge which should work with your lights.
Contact your supplier for the instruction set. If you have difficulty getting it I think I still have it on my work laptop.
HTH
V.
Be careful out there forumites - 89% of statistics are made up.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
vex is offline   Reply With Quote
flashing, lutron
Copyright © 2000-2010 M2N E. & O. E.
