Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Home Automation, Lighting and Climate Control
Latest AVForums Movie Reviews
Zombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray Review
Clash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray Review
Thread Thread Starter Forum Replies Last Post
LCD Projector yay or nay? D-man Projectors 4 26-05-2009 5:19 PM
Alloy wheels - Yay or Nay Hitby Motoring 61 07-05-2009 3:58 PM
Credit card yay or nay? GATESHEAD MOB General Chat 60 06-04-2009 2:45 PM
HD70: (fingerprint?) smudge on the inside of the lens after repair lapino Projectors 1 18-03-2009 9:33 PM
Old 11-06-2009, 1:37 PM   #1 (permalink)
Thanks: Gave 62, Got 121
Fingerprint Lock... yay or nay
Getting a new home cinema room/music studio installed (loft conversion which will occasionally be used as a guest room) and as I'm on a spending spree (single handledly doing my bit to prop up the economy!) I thought about getting a fingerprint lock installed at the same time as the firedoors have to go in...
Don't want to blow a massive amount, but this looked good (and has that "gadget factor" even though there are probably much fancier and more expensive units out there)
Q-See QSB180 Fingerprint door Lock with Keypad: Amazon.co.uk: DIY & Tools
Any thoughts? Pros? Cons?
Shiny Gizmos, Shiny Gadgets and Stuff with flashing LEDs.. all with an A+ "Wife Approval Rating(tm)"
jms_uk is online now   Reply With Quote
Old 23-06-2009, 12:27 PM   #2 (permalink)
j4ck100's Avatar
Thanks: Gave 7, Got 4
Re: Fingerprint Lock... yay or nay
Looks good to me!!
Although I would do a bit more research to make sure that it won't lock you out of your media room!
j4ck100 is offline   Reply With Quote
Old 23-06-2009, 6:56 PM   #3 (permalink)
skydivemacca's Avatar
Thanks: Gave 32, Got 17
Seems a bit pointless as it has two of its three options to open it without using a finger print.
I think there are other options out there at your price point, might be worth more of a look around
Cool idea
skydivemacca is offline   Reply With Quote
Old 24-06-2009, 6:08 PM   #4 (permalink)
D4RK1's Avatar
Thanks: Gave 27, Got 20
The gadget factor is there, but man that door handle is fugly! Any biometrics will impress, have a look for a retinal scanner, less likely to get yer eyes picked out than a measely finget lopped off haha
D4RK1 is offline   Reply With Quote
Old 22-07-2009, 1:05 AM   #5 (permalink)
Thanks: Gave 2, Got 3
Demolition man springs to mind...
Temujin is offline   Reply With Quote
Old 26-07-2009, 4:59 AM   #6 (permalink)
Thanks: Gave 17, Got 56
i found one...
here
i love this bullet point they thought they had to add.
  • "Suitable for everyone: Suitable for everyone with eyes"
My Command Center: Samsung M87 HDTV
Xbox 360 Elite + HD DVD Add on
2x Xbox Premium's, SphereX 5.1
Custom Built Quad Core Windows 7 Ulitmate RTM x64 PC
EDDS is offline   Reply With Quote
Old 27-07-2009, 6:48 PM   #7 (permalink)
Thanks: Gave 29, Got 5
these came out a couple of years ago (the finger one) so there should be plenty fo reviews and hopefully updated products avail
keep us informed i am interested to see how they work
Tfish is offline   Reply With Quote
Old 30-07-2009, 7:16 AM   #8 (permalink)
jt2k6's Avatar
Thanks: Gave 6, Got 7
my set up
32" toshiba regza / sky+
PS3 Slim 250gb / wii black
jt2k6 is offline   Reply With Quote
fingerprint, lock, nay, yay
Copyright © 2000-2010 M2N E. & O. E.
