Fridge/Freezer Seal Warranty
Old 03-07-2012, 1:51 PM   #1
Thanks: Gave 1,539, Got 424
Hiya,
The door seal on the freezer section doesn't make contact with the actual frame, so there is a 5mm gap all the way along the top of the door (the sides are fine).
This has resulted in massive build up of frost (frost free appliance). Phoned Hotpoint who say seals are not covered under warranty so would be subject to parts + £120 call out fee (to replace a ****ing seal!!).
I cannot belive this to be the case as they're saying that if on delivery it was ****ed I'd still have to pay this.
It's only just over 7 months old.
Crooks. Really are. What alternatives to refrigeration are there. If what they're saying is true i'd rather not have one as this is the second model in 1 year to have failed (the problem with the first one wasn't covered either).
Old 03-07-2012, 3:03 PM   #2
961 961 is offline
Thanks: Gave 223, Got 613
This is probably due to misalignment of the door. The manual should show you how to adjust it so that all four edges are in contact with the carcass of the freezer
While the seal may not be covered under warranty it is likely that if the retailer was approached in a polite manner (without being called a crook or the use of the **** word) he may well agree to repair or adjust the door
Old 03-07-2012, 7:57 PM   #3
I'm not so sure you know, as the seal at the top of the door kind of bows in the middle, so the outer edges are in contact with the carcass, but the middle is not.
I've tried heating the seals with a warm cloth but after time it reverts back.
I went direct to Hotpoint so my next point of call would be the retailer.
Old 08-07-2012, 9:44 AM   #4
Thanks: Gave 40, Got 60
If the seal isn't split then it's not faulty and WILL be down to adjustment of the door.
Old 08-07-2012, 1:59 PM   #5
Thanks: Gave 78, Got 96
If you need to replace the seal yourself, then have a look here Appliance Spares, Spare Parts and Accessories - BuySpares UK Price should be resonable.
Old 08-07-2012, 4:37 PM   #6
961 961 is offline
Often an easy fix is to use superglue or evostick to glue centre of door seal to the door so that it doesn't sag
Old 14-07-2012, 8:03 PM   #7
Forgot about this.
Engineer came out on Tuesday. Not the seal (at all). The carcass has deformed (bowed) away from the seals!
Replacement required, but discontinued but new model (to replace my one) coming soon.
Old 15-07-2012, 3:32 PM   #8
961 961 is offline
Originally Posted by ldoodle View Post
Forgot about this.
What great news!
As a general enquiry, can they replace my 73 year old carcass 'cos I'm having the same sort of problems
Old 18-07-2012, 10:21 AM   #9
Just an update (and request) on this. The replacement model will not be available until next year at the earliest.
So I need a 700mm wide fridge, but the usual stores don't seem to stock them - any ideas. I did think the Hotpoint Quadrio but even that's EOL now so I see from some places!
Need bigger fridge than freezer.
