Oven heating element replacement
Old 08-05-2009, 8:41 PM   #1
Naaktgeboren's Avatar
9,062, Level: 22
Points: 9,062, Level: 22 Points: 9,062, Level: 22 Points: 9,062, Level: 22
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 320, Got 531
I am looking to replace a heating element in my Hotpoint EW82 and wonder if anyone has done a similar job recently.
I can see all the screws etc that need to be removed in order to expose the element, is it simply a matter of unscrewing the element and fitting a new one in or is there anything else I have to bear in mind for the job?
Old 09-05-2009, 7:51 AM   #2
russ123's Avatar
3,760, Level: 14
Points: 3,760, Level: 14 Points: 3,760, Level: 14 Points: 3,760, Level: 14
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 26, Got 44
Re: Oven heating element replacement
Not done a Hotpoint but on my Smeg it is exactly as you describe and couldn't be easier. Just turn it off before .
Mine has two and they go regularly, every 18months or less. The first time I got an engineer out but the second time as it was so recent I figured it was an expensive exercise and saved myself 100 quid
Old 09-05-2009, 8:09 AM   #3
9,062, Level: 22
Activity: 6.1%
I am guessing you simply unplug some kind of lead from the old element and reconnect to the new one, is it as easy as that?
Old 09-05-2009, 11:27 AM   #4
russ123's Avatar
3,760, Level: 14
Activity: 1.0%
Yep just female spade connectors.
Naaktgeboren (09-05-2009)
Old 09-05-2009, 11:11 PM   #5
IronGiant's Avatar
25,220, Level: 38
Points: 25,220, Level: 38 Points: 25,220, Level: 38 Points: 25,220, Level: 38
Activity: 29.4%
Activity: 29.4% Activity: 29.4% Activity: 29.4%
Thanks: Gave 2,347, Got 4,998
Ah, a fellow Smeg two element oven owner , I bet you can do it in the dark by now?
Back on topic,
As he says, it should be really easy.
Dave
Old 10-05-2009, 11:40 AM   #6
russ123's Avatar
3,760, Level: 14
Activity: 1.0%
Ahh so it isn't just mine then
I inherited it with the house when it was only 9 months old and it went within another 3. If I'd not worked out how to do it myself it probably would have been cheaper to buy another oven by now
.... and it wouldn't be a Smeg!
Old 10-05-2009, 10:07 PM   #7
9,062, Level: 22
Activity: 6.1%
I had a little look today, only problem is the light fitting which apparently needs to be screwed off in order to release the back plate. I am either missing a trick or mine has jammed solid, I just cannot get any movement out of it
Old 05-06-2009, 5:41 PM   #8
1,343, Level: 8
Points: 1,343, Level: 8 Points: 1,343, Level: 8 Points: 1,343, Level: 8
Thanks: Gave 12, Got 11
My Smeg element has gone again, i bought a cheap £10 replacement last time.
is there any benefit in buying a genuine part? i.e will it last longer!!
Old 05-06-2009, 6:05 PM   #9
IronGiant's Avatar
25,220, Level: 38
Activity: 29.4%
I doubt it, my cheap replacements have lasted much longer than the originals did.
Dave
Grale16v (05-06-2009)
Old 05-06-2009, 6:18 PM   #10
1,343, Level: 8
Dave
Thanks, getting quick at changing them now!!
Old 05-06-2009, 11:46 PM   #11
4,944, Level: 16
Points: 4,944, Level: 16 Points: 4,944, Level: 16 Points: 4,944, Level: 16
Thanks: Gave 36, Got 43
Check also that the fan is switching on and off as it is suppose to and that the air vents are not blocked as that can dramatically reduce the life of the element.
-Neil
Powered by
 Latest popular product prices
Dyson DC03 Absolute Plus Zorb
2 prices from
 £9.00 Click to show/hide the offers
2 prices from
2 prices from
2 prices from
2 prices from
Morphy Richards 47094
3 prices from
 £28.99 Click to show/hide the offers
3 prices from
3 prices from
 Updated February 13th at 8:30pm. Prices include delivery.
