Fridge Freezer issues - help!
Old 01-08-2008, 5:46 PM   #1
Kieron's Avatar
18,449, Level: 32
Points: 18,449, Level: 32 Points: 18,449, Level: 32 Points: 18,449, Level: 32
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 2,515, Got 1,863
Hi all.
Ok, power on, light on in fridge part.
Totally defrosted though. It's a frost free Beko.
No noise from compressor.
Any ideas?
Old 01-08-2008, 6:26 PM   #2
Conspicuous Member
PJTX100's Avatar
16,232, Level: 30
Points: 16,232, Level: 30 Points: 16,232, Level: 30 Points: 16,232, Level: 30
Thanks: Gave 402, Got 566
Re: Fridge Freezer issues - help!
Has the door dropped because of weight of stuff in the in the door shelves, and isn't quite pushing the door-closed switch enough?
Happened to us. Xmas day too.
A £50 organic turkey replaced with a Bernard Matthews half-frozen turkey joint. Yum.
Edit: Oh yeah, it could be the thermostat too. Usually cheap to replace. Do a google. Fixed our fridge for a tenner or so.
Edit 2: http://www.fridgeshop.net/
Kieron (01-08-2008)
Old 01-08-2008, 7:47 PM   #3
4,189, Level: 15
Points: 4,189, Level: 15 Points: 4,189, Level: 15 Points: 4,189, Level: 15
Thanks: Gave 81, Got 49
Smile Re: Fridge Freezer issues - help!
Our fridge-freeezer was playing silly buggers last week too. Over the weekend when it was quite hot the fridge temp (there is an lcd display that shows fridge and freezer temps) went up to 10 degC and the freezer went up to -10degC (usually -20).
After investations it seems to be the fridge door not closing/sealing properly!
It seems to be working fine now (much to DW's disgust as she wanted a new American style fridge-freezer)
Old 02-08-2008, 12:21 AM   #4
razz1979's Avatar
2,239, Level: 10
Points: 2,239, Level: 10 Points: 2,239, Level: 10 Points: 2,239, Level: 10
Thanks: Gave 94, Got 45
Or it could just be the fact it is a Beko?! Several years ago I had a Beko washing machine of which the weight fell of the bottom, (after 13 months ) obviously after speaking to their customer service it turned out it was nothing to do with them. (also had a 21" tv from them: No better)
I just cut my losses & decided never to buy that brand again.
Old 02-08-2008, 1:00 AM   #5
Kieron's Avatar
18,449, Level: 32
Activity: 3.9%
It was the thermostat. I've bypassed it now to get it working again until I can get a new one delivered.
Old 13-09-2008, 11:55 AM   #6
Illustrious Member
JohnG's Avatar
41,487, Level: 49
Points: 41,487, Level: 49 Points: 41,487, Level: 49 Points: 41,487, Level: 49
Activity: 14.5%
Activity: 14.5% Activity: 14.5% Activity: 14.5%
Thanks: Gave 2,203, Got 1,081
How do you bypass the thermostat ? I've just got home from a week away to find the fridge light is on but it's warm inside
Old 13-09-2008, 12:36 PM   #7
IronGiant's Avatar
25,218, Level: 38
Points: 25,218, Level: 38 Points: 25,218, Level: 38 Points: 25,218, Level: 38
Activity: 29.1%
Activity: 29.1% Activity: 29.1% Activity: 29.1%
Thanks: Gave 2,347, Got 4,997
Kieron: Do you have a time switch you can plug it into so it comes on for half an hour, then off for half an hour? If you run the compressor permanently you could damage it and that would not be easy to fix. With a bit of fiddling you can work out the best on/off ratio to keep it running at a suitable temperature.
John: The mains supply to the compressor is interupted by the thermostat. If you route the mains direct to the compressor it will run permanently, assuming it was the thermostat at fault (it usually is). The usual caveats of don't try this unless you know what you are doing apply to anything involving mains electricity...
Dave
JohnG (13-09-2008)
Powered by
 Latest popular product prices
Dyson DC03 Absolute Plus Zorb
2 prices from
 £9.00 Click to show/hide the offers
2 prices from
2 prices from
2 prices from
2 prices from
Morphy Richards 47094
3 prices from
 £28.99 Click to show/hide the offers
3 prices from
3 prices from
 Updated February 13th at 6:30pm. Prices include delivery.
