Well, the kitchen re-fit is proceeding at a fair pace.. due to being in a hard water area, we've finally gone ahead and had a Dualflow water softener fitted with a hard water (mains) feed to the cold tap of the kitchen sink.
We've also bought a Panasonic NR-B53V1-XB american style fridge freezer which has a filtered chilled water dispenser.. so my questions are..
Soft water for drinking?
There are a number of articles about the suitability of soft water for drinking. The most consistent info I can find is that its ok if you don't suffer from high blood pressure/elderly/baby (the arrangement I have above mitigates this issue if only drinking direct from that hard water tap feed)
Given we've got the option to plumb the fridge freezer into either a hard or soft water feed (both options are equally easy to do with the new plumbing that's just gone in), and the Panny has a water filter built in.. so, can anyone give advice on which we should use?
There is absolutely nothing I can find on the net about the advantages/disadvantages of further filtering soft water..
Thanks in advance
