Bosch oven PCB has gone BANG!
Old 02-05-2012, 3:09 PM   #1
Thanks: Gave 1, Got 9
Hi I have a combination Microwave oven/Grill/Oven that broke some time ago. The model number is BOSCH Gourmet- HFT879.
I am either after a replacement in stainless steal or the actual PCB repaired.
Can these be sourced?
The model looks like this
Old 04-05-2012, 4:03 PM   #2
Thanks: Gave 48, Got 349
You can buy original spare parts here:
http://www.bosch-home.co.uk/store/spareparts/search
Old 05-05-2012, 8:20 AM   #3
Chadford's Avatar
Thanks: Gave 851, Got 1,004
Looks like a nice piece of kit, I'd seriously look at getting it repaired rather than replacing it.
I'm pretty sure you wont be able to get the PCB repaired (uneconomical), but you should be able to get a replacement PCB, probably something like £100-£150.
I've just done a similar thing with my faulty fridge freezer and it worked out at about 1/7th of the cost of buying a new one.
Just a thought, If you're fairly handy it's worth looking at the PCB. In some cases these sort of devices contain relays that one of the power pins on the PCB burn the PCB's copper track and can be very easily repaired. I've fixed my Bosch dishwasher PCB with this problem and also a friend's bread-maker PCB. i.e...
Broken...
Fixed...
