I'll grant you the spin speed (ours tops out at 1100) and the Kg or so on the capacity.
Not sure about the 'more programs' or energy efficiency (ours is A rated with a C rating on Spin).
Modern machines are now rated up to A++ energy efficiency due to the fact that the tech has moved on, an A rating for spin is possible on machines with a spin of 1600.
I'd actually argue it is probably performing better than it did 15 years ago. The machine hasn't changed, but the quality of detergents certainly has.
While you may be getting better stain removal and cleaner clothes due to the better detergents in your machine, with a newer model you would get better results from less of the same detergents at a lower temperature, using less water and less energy. Surely thats an improvement.
That's impossible to judge - all I know is the total cost of ownership is probably way lower.
I'll agree that going out and spending on a new machine may not be right for you while yours is working to the level you expect and are happy with. Even a 15 year old Miele (the best make, no doubt) will not be as good as a modern Miele (and one reason your machine is as white as the day you bought it, is that Miele never used to make their machines pure white
