New fridge/freezer oddity
Old 07-09-2009, 5:47 PM   #1
2,300, Level: 11
Points: 2,300, Level: 11 Points: 2,300, Level: 11 Points: 2,300, Level: 11
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 20, Got 269
I had one delivered last week and it's been running for a few days now.
Having given it time to settle down I've discovered that using the highest thermostat setting to keep the fridge temp correct results in the freezer being close to -30ºC which is way too cold! Could easily result in food suffering freezer burn, which does it not good at all.
Is there any way to adjust the balance between the two, or should I be looking at sending it back?
Old 07-09-2009, 5:58 PM   #2
2,231, Level: 10
Points: 2,231, Level: 10 Points: 2,231, Level: 10 Points: 2,231, Level: 10
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 493, Got 554
Re: New fridge/freezer oddity
What do you mean, the highest thermostat setting? The higher the number, the colder it gets.
About a third of the way up the scale is usually ample.
Old 07-09-2009, 6:19 PM   #3
Ayub's Avatar
6,659, Level: 19
Points: 6,659, Level: 19 Points: 6,659, Level: 19 Points: 6,659, Level: 19
Activity: 0.7%
Thanks: Gave 639, Got 466
Please state make and model. On digital displays when you press + which you would think is turning the freezer temp highter ( to cool it is actually turning the temp up to warm it) kinda the opersite of what you actually want.
Hotpoints have that
Old 07-09-2009, 6:22 PM   #4
Newton's Ring's Avatar
3,966, Level: 14
Points: 3,966, Level: 14 Points: 3,966, Level: 14 Points: 3,966, Level: 14
Thanks: Gave 134, Got 62
Mine's -20 in the freezer and 3deg. in the fridge.
Old 07-09-2009, 6:25 PM   #5
Phil57's Avatar
3,209, Level: 13
Points: 3,209, Level: 13 Points: 3,209, Level: 13 Points: 3,209, Level: 13
Thanks: Gave 600, Got 310
Hotpoints have that
Back in my days at school................+ raises the temperature IE less cold-warmer.
Old 07-09-2009, 6:27 PM   #6
Phil57's Avatar
3,209, Level: 13
What temperature do you consider to be correct for the fridge?
Old 08-09-2009, 5:09 PM   #7
2,300, Level: 11
Activity: 2.3%
That's what I would hope for. It's a BEKO with a manual stat setting. I started it at 5 (0-6) and gradually backed it down over a couple of days to 3.5. Earlier today it was 8º in the fridge and -26º in the freezer.
The balance is all wrong.
Old 08-09-2009, 5:36 PM   #8
shoestring25's Avatar
12,839, Level: 27
Points: 12,839, Level: 27 Points: 12,839, Level: 27 Points: 12,839, Level: 27
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 26, Got 81
mines set at 3 for the fridge and -16 for the freezer. ideal settings are -18 for the freezer and 3 for the fridge. i have mine set at -16 because I'm tight and it saves some electric this way
Old 08-09-2009, 6:40 PM   #9
2,757, Level: 12
Points: 2,757, Level: 12 Points: 2,757, Level: 12 Points: 2,757, Level: 12
Thanks: Gave 4, Got 33
Ok ,I think what the OP is getting at is that there is only one thermostat control for fridge and freezer combined and that to have the fridge at say 3 c means that the freezer is too cold.
I would send it back as unfit for purpose.
Old 08-09-2009, 7:09 PM   #10
darkcloud2011's Avatar
4,429, Level: 15
Points: 4,429, Level: 15 Points: 4,429, Level: 15 Points: 4,429, Level: 15
Thanks: Gave 621, Got 206
should this not be here Home Appliances (Cooking/Cooling/Cleaning) - AVForums.com
Old 08-09-2009, 7:15 PM   #11
4,466, Level: 15
Points: 4,466, Level: 15 Points: 4,466, Level: 15 Points: 4,466, Level: 15
Thanks: Gave 0, Got 13
Have you checked the blower between the freezer and fridge. I had one go out which had the same symptoms you're seeing.
Powered by
 Latest popular product prices
Dyson DC03 Absolute Plus Zorb
2 prices from
 £9.00 Click to show/hide the offers
2 prices from
2 prices from
2 prices from
2 prices from
Morphy Richards 47094
3 prices from
 £28.99 Click to show/hide the offers
3 prices from
3 prices from
 Updated February 14th at 1:30am. Prices include delivery.
