Originally Posted by Stuart Wright Our carpets are in bad need of a deep clean. Mud, oil, marmalade and toffees.
Are there any experts who can recommend what is the most cost effective method?
TIA |
Dont bother hiring the rug doctors its more hassle than its worth by the time u have spent money on the hire, the solutions not to mention the poor cleaning quality and carpets wet for days on end you might as well just get proffesionals in.
Profesionals will charge the same rate whether carpets are dirty or really dirty makes no difference if you have attempted with a rug doctor. Usually they give you a few free stain removals, this could be 4 or 5 spots where you have stains so they will spray chemical onto these and then leave to soak and work on them more.
The problem with the machines you can hire to do it yourself is the chemicals and poor extraction rates of machines.
The cleaning fluids stick to the carpet and are not effectivly rinsed out meaning that the fluids attract dirt more quickly and look dirtier needing doing again sooner.
The proffesionals use an alkaline chemical that is sprayed onto the carpets, agitated with brushes left to soak and then they rinse this with an acid rinse solution which neutralises it. There is no soap involved which is what most of the domestic products you can buy contain.
We get ours cleaned yearly by a bloke who has a truck mounted unit.
The vacuum and cleaning unit is in the back of his van and powered by diesal engine so it is very powerful.
Carpets are spotless after and dry in a few hours.
Plus you dont have to mess around doing it yourself.
Expect to pay about £80 for a 2 bed house. Costs a little more than doing it yourself but its a great result.
I work in the cleaning industry and know a lot into this trade etc.
No need to replace the carpets if they are not worn, you will be amazed at how good they will come up with a proper deep clean.
Another tip... dont use carpet freshening powders like shake and vac as its such a fine powder it gets left behind in the pile and attracts dirt!
Hope this helps.
Richard.
