Originally Posted by Chaosx Do you mean the filter that is on the back can be moved then? Because I've done some reading and the only complaint is that it sticks out a bit from the wall. |
The back of my fridge is completely flush, nothing protruding. The filter connects into mains water, then you have a 5mm tube from the filter to a tiny entry hole at the back of the fridge. The tube they provide is massive hence you can pretty much put the filter wherever.
From the others i've seen, the filter clips on at the back-top, whereas my one is a (what looks like) oversized syringe that has mounts to fix to a wall, independant of the fridge.
Maybe my model is slightly different (picture looks identical). Will check when I get home.
