AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 19-06-2007, 7:26 PM   #1 (permalink)
Thanks: Gave 5, Got 10
Unhappy scart to hdmi ? or scart to component adapters ?
hi
i have the LE46M87BDX samsung tv
and as you may already know there is a problem with lines going down the side of the tv when using the scart connection on this tv.
i use a virgin media box,and dont want to upgrade to the V+ box yet,so i am wondering can you get a adapter that goes on the end of the RGB scart lead that adapts to HDMI or COMPONENT ?
This should then not produce the lines,and yes i will get the tv fixed when they come up with a fix for this problem but this might sort it in the meantime.
trapster is offline   Reply With Quote
Old 20-06-2007, 3:47 AM   #2 (permalink)
Kramer's Avatar
Thanks: Gave 5, Got 31
Re: scart to hdmi ? or scart to component adapters ?
RGB to component is easy & relatively cheap. I've been using this for several years & can't fault it.
RGB to HDMI is more expensive. You're really looking at scalers at that stage. There are some cheaper options available but I have no personal experience with these & I'm not sure if they'll do direct RGB conversion:
http://www.tmfsolutions.co.uk/Gefen_HTScaler.htm
Many newer receivers do format conversion too but usually from composite/s-video to component/HDMI etc.
I'd say the JS-Tech scart>yuv would be the best option.
Kramer
My personal opinions expressed here are not necessarily those of the AV Forums or other related websites, but you all know that
Kramer is offline   Reply With Quote
adapters, component, hdmi, scart
Refbacks are On
AV ForumsOptimised for Firefox.
