AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 19-06-2007, 10:51 AM   #1 (permalink)
Thanks: Gave 4, Got 0
HDMI / Optical and a PS3
I am about to buy my first HD plasma screen and am a little confused.
The main issues are...
My playstation 3 carries HDMI v 1.3 however the Samsung TV only seems to have HDMI version 1.2...
I don't have an Amp with HDMI but it does have optical in
So I was hoping to connect the ps3 directly to my screen using hdmi then use optical to the amp for sound...
I am already hearing things about the PS3 and its optical connections not working with HDMI
is this something that will work or do I need a new amp with HDMI?
snooopy is offline   Reply With Quote
Old 19-06-2007, 6:28 PM   #2 (permalink)
Thanks: Gave 8, Got 385
Re: HDMI / Optical and a PS3
Originally Posted by snooopy View Post
You can use HDMI to connect your PS3 to your display for vision, and optical for audio. I've done this at home.
HOWEVER - it is either/or in audio terms - when you chose optical out, the HDMI audio is switched off (so in some installations where people use the TV speakers via HDMI for gaming, but home cinema amp for BluRay, you have to change the settings each time)
ALSO - the optical audio output will only carry 2.0 PCM, and DVD-quality Dolby Digital or DTS audio. You don't benefit from the higher quality audio that HDMI audio offers - where the PS3 can decode the newer audio codecs to 5.1 PCM or replay uncompressed 5.1 PCM tracks.
(5.1 PCM won't fit down a standard Toslink optical connection)
Stephen Neal is offline   Reply With Quote
snooopy (19-06-2007)
hdmi, optical, ps3
Refbacks are On
AV ForumsOptimised for Firefox.
