I've now filled up my HD inputs - are there devices which you can use to split or share inputs?
I've two HDMI (one for sky hd and one for dvd player)
one component which is used for the x-box 360.
I really need to use the component from my PC graphics card - any ideas?? I may be able to sacrifice the hdmi from the dvd and use good old scart... but not sure if the component to hdmi would work??
Usually when you want to mix/combine Digital and Analogue Sources you require a relatively expensive Video Processor (Scaler) though Gefen have a new 'low cost' 2 x Digital + 2 x Analogue Switch with on-board scaling/conversion that may be of interest; see http://www.gefen.com/kvm/product.jsp?prod_id=4174
