[FONT="Comic Sans MS"]I have a Sammy LE32R73BD & have just had Sky HD installed. The engineer says that the TV couldn't support HDMI connection due to the Digital Copy Protection signal within the HDMI signal. He tried the lead & the TV said it wasn't supported. I must assume that this is correct (although I seem to be the only one with this problem with this TV?).
Do I need to use a HDMI to DVI lead to connect the HD Box to the TV & will this solve the problem. I currently have it connected via component but the quality will not be as good (?)
Thanks for reading
[/FONT]
