AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 18-11-2006, 5:27 PM   #1 (permalink)
Thanks: Gave 33, Got 186
Couple of questions regarding Resulutions and scaling.
1) Will there we a noticable difference between 720p on a 1366 x 768 screen and a 1920 x 1080 screen?
2) Will 1080i on a 1920 x 1080 screen look better than 720p on a 1366 x 768 screen due to its interlaced nature?
3) On a 1920 x 1080 screen, which will look better 1080i or 720p?
Thanks, reason I'm asking is that i wont have any 1080p sources for a while.
Main Kit: Samsung 37A558 / Sky+ / Sony HTSS1000 / Sony RDR-GX120 / Toshiba HD-E1
Bedroom Kit: Sharp 32X20E 1080p/ Acoustic Solutions DS 534 / Xbox 360 Elite + HD DVD
Laptop: Rock Pegasus 670 - 15.4" WSXGA / C2D 2.2GHz / 8600M GT 512mb / 2GB RAM & 2.5TB HDD
Batch is offline
Old 18-11-2006, 7:15 PM   #2 (permalink)
Re: Couple of questions regarding Resulutions and scaling.
anyone?
Batch is offline
Old 18-11-2006, 8:08 PM   #3 (permalink)
AndyCob's Avatar
Thanks: Gave 23, Got 58
Ok loaded question that can produce disagreement.
My answers:
1. Probably not much, does depend on the quality of the internal scalers and personal preference
2. It should if it is native 1080i, particularly if it is film based material and the deinterlacer is good quality. If it is upscaled then it's entirely dependent on screen/scaler quality. Good deinterlacing of film material should make interlaced versus progressive redudant however many cheap internal scalers/deinterlacers just aren't that good.
3. Again if it's native 1080i and the deinterlacer is good it should be better. With film material a good deinterlacer should take the 1080i feed deinterlace to 1080p 24/25hz and display as 1080p using 3:2, 2:2 frame repition etc.
If your only 1080/720 sources are upscaled DVD then there are to many variables in the sclaers/screen etc to guarantee the 1080 screen will look better. However if you have sky HD then the 1080 screen should give a better picture and the picture should absolutely be better once you get a 1080 source from HD-DVD or Blu-Ray.
AndyCob is offline
Old 18-11-2006, 8:29 PM   #4 (permalink)
Thanks!
I'm looking at getting a Sharp XD1E and will have the Xbox 360 and Toshiba HD E1 HD DVD Player as sources. All HD DVD's are 1080p so i assume the player will interlace it, output it as 1080i and then the TV will detintercace in to 1080p?
Batch is offline
Old 19-11-2006, 5:05 PM   #5 (permalink)
Thanks: Gave 6, Got 13
Yes but don't expect inverse telecine.
Quickbeam is offline
couple, questions, resulutions, scaling
Refbacks are On
Thread Thread Starter Forum Replies Last Post
HDMI Up-Scaling Questions jezzer256 Integrated AV Amplifiers and Receivers 21 08-12-2006 5:33 PM
Some newbie questions regarding pixels and scaling trashpost LCD Televisions 0 25-10-2006 1:38 PM
436-XDE Scaling Questions kamaran Plasma Televisions 7 05-10-2005 8:43 PM
A couple of htpc questions (scaling, relative quality etc.) meoq Computer Systems 8 07-10-2004 2:58 PM
z1 v ae300 v hs10 (and scaling/res questions) martintyler DLP, LCD and D-ILA Projectors 5 18-02-2003 5:22 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
