AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 29-10-2006, 3:09 PM   #1 (permalink)
steptuk
Posts: n/a
HDMI DVD -TV connection problem
hi
Please can anyone help.
I have a Samsung LE40R7 HD ready LCD TV. Yesterday I bought an LG DNX190UH DVD Player which upscales via an HDMI cable (supplied with player).
I connected the TV and DVD via HDMI and all worked fine - DVD played etc.
Tried later and rather the the LG "screen saver" a got a flashing blue then green screen. After turning DVD player on and off and playing with the resolution setting I got the screen saver up, but when i loaded a DVD got the blue/green flashing screen back.
I took the DVD player back to Comet, they set it up with the same TV model- worked fine. So I took it home- still had problem. Took the DVD player back to Comet- they changed it for a new one- Tried again at home -same problem. The fault is obviously with the TV. Any suggestions as cause of problem. ? HDMI cable- have tried 2 now- both same. ? TV HDMI interface blown? is that possible?
Thanks Steve
Old 02-11-2006, 7:43 PM   #2 (permalink)
steptuk
Posts: n/a
Re: HDMI DVD -TV connection problem
Think my question has you foxed!
anyway- had an engineer look at a TV today- it appear HDMI socket is blown and a new PCB card is required. So I have to wait another week before it can be fixed.
Problem is not that uncommon apparently- anyone else had similar. I worried if I should have taken a an extended warranty!
Steve
Old 13-01-2007, 7:23 PM   #3 (permalink)
hi, just noticed your post about the screen flashing green. i have just today purchased a DNX190UH and connected it to my LG 50PX4D plasma. set it all up and when i switched it on the LG logo was pink!! i put a film on to find it all in a vivid shade of pink but then the screen flickered green and the sound was very broken and crackly. at the moment i have it on the component input which i guess i will have to put up with till it is fixed. did you notice poor sound and did the connection work intermitently? i am going to ring Comet up on monday but if they come and inspect my TV and it is found not to have a fault i am charged.
vancreef is offline
connection, dvd, hdmi, problem
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Denon 2910 HDMI Connection problem EBT DVD Players (Standard Definition and Upscaling) 1 14-08-2006 6:27 PM
HDMI connection problem from dvd to lcd carleast LCD Televisions 5 02-05-2006 6:33 PM
HDMI connection problem from dvd to lcd carleast DVD Players (Standard Definition and Upscaling) 1 01-05-2006 3:43 PM
P50/HDMI/PC. connection problem! Help please! cu3ed LCD Televisions 1 20-01-2006 4:26 PM
Infocus 5700 hdmi connection problem. Wiggins DLP, LCD and D-ILA Projectors 0 24-07-2005 1:30 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
