AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 29-10-2006, 12:05 AM   #1 (permalink)
Exclamation Need Help Buying HDTV?!
Im having trouble finding a decent HDTV 27'' + for £400 - £500, although on www.pixmania.com, i found a rather decent 27'' samsung HDTV for just £442, i know its not a lot of money for a HDTV but im in need of one, the other cheap HDTV's that are 27'' + are the make 'MIARI' which i have never heard of really, and they make a 32'' for i think £450 or £500, but i dont know if they're a good make, i just want to see if you can find some better products or if i should stick with a 27'' samsung instead of a 32'' MIARI.
Thanks for any help
Tom Wells-Day
Socoms is offline
Old 29-10-2006, 12:04 PM   #2 (permalink)
Sonic67's Avatar
Thanks: Gave 523, Got 683
Re: Need Help Buying HDTV?!
Play does a 26" Phillips for £500. More well known make anyway.
Here
Sonic67 is offline
Old 29-10-2006, 12:15 PM   #3 (permalink)
Chris Muriel's Avatar
Thanks: Gave 87, Got 253
It's a MIRAI - just in case someone tries a Google or AVforums search and draws a blank due to the typing error.
Chris Muriel, Manchester
Chris Muriel is offline
Old 29-10-2006, 7:58 PM   #4 (permalink)
any chance of finding a decent make with a 29'' + for £575 max?
Socoms is offline
buying, hdtv
Refbacks are On
Thread Thread Starter Forum Replies Last Post
***|>What to look for when it comes to buying a HDTV <|*** Nielo TM High Definition TV Hardware 34 25-07-2006 12:11 AM
Buying A HDTV RichBaines High Definition TV Hardware 2 24-03-2006 7:07 PM
Worth buying a HDTV now? addit High Definition TV Hardware 16 31-10-2005 5:37 PM
Advice on buying LCD HDTV CHRIS1977 High Definition TV Hardware 4 26-10-2005 6:45 PM
Should I be buying HDTV now? Peritas High Definition TV Hardware 11 14-08-2005 10:38 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
