Originally Posted by mr december
I have a Samsung LE40R73BD TV & a Samsung HT-Q20 Digital Home Cinema System. I have connected my SKY HD box using the HDMI lead, no problem there. I have coneected the Home Cinema DVD player using a Componet Video Cable as recomended by Samsung, but when I select the Video I get a message stating "No SourceAvailable". If I use normal AV leads everything is fine. I've rung Samsung helpline - no help. Any ideas please.
Hello Mr D
i think i have the answer if you have not already found it,
my brother in law bought the same home cine system and had the same problem, he took it back to currys thinking it was faulty, i went round and had a look, the answer is with the remote that comes with it, you have to hold down thep.scan button for 5 seconds to activate it, it should be fine after that, let me know
regards
gary
