AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 23-10-2006, 8:23 PM   #1 (permalink)
Thanks: Gave 57, Got 6
Swisscenter help
I have installed the above and I'm having a problem with the config. I can create media locations and they seem to be accepted but when I create the database I get the error that no locations have been created. When I go back to the locations page, sure enough the locations I created are no longer there
No Mr Bond, I expect you to DIE!!!
Mike-M is offline
Old 24-10-2006, 3:47 PM   #2 (permalink)
Caoimhghin's Avatar
Thanks: Gave 3, Got 20
Re: Swisscenter help
Did you finally get swisscenter working?
I initially had the same problem, but after restarting my PC and launching the configuration utility this page loaded. This didn't happen before so I guess it needed a reboot to start the database, though this seems strange.
Caoimhghin is offline
Old 24-10-2006, 7:19 PM   #3 (permalink)
I think I'll give up on this. I have had no success with setting media locations to either a networked drive or a NAS no matter what I tried. I tried a folder on the local drive and that seemed to work. I got the page you show and a couple of of test files did show up on the TV, once. They promptly disappeared again and since then I've got no where with it.
Mike-M is offline
Old 24-10-2006, 9:20 PM   #4 (permalink)
Caoimhghin's Avatar
Have you checked the log file in the simese\data\log folder? It lists all the files added to the database.
You have updated the media database? You have to do this every time you add media, unless you've changed the settings to update at regular intervals.
swisscenter
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
