AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 21-04-2006, 3:36 PM   #1 (permalink)
Chris Muriel's Avatar
Thanks: Gave 90, Got 261
HiDef demo/tests on Hispasat, 30W
Been watching the following on Hispasat at 30 degrees west:
12042H SR13270 3/4 VPID150 APID 151 PCR 150 MPEG2
Showing 1080i clips, some in English.
Video bitrate is 15 Mbps max (was 14.64 when I was watching).
Noted some jaggies on straight edges in motion/panning shots (opera singers dress was one example).
Interestingly my old Nokia STB (with DVB2000 firmware) made a half decent job of showing this (just stuttered and went black every 6 seconds or so) ; it doesn't do as good a job on HD1 etc.
Looks great via PC though.
Chris Muriel, Manchester
Chris Muriel is offline   Reply With Quote
Old 21-04-2006, 7:26 PM   #2 (permalink)
Thanks: Gave 8, Got 385
Hi Chris - were the jaggies dodgy de-interlacing artefacts do you think (i.e. 50i converted to 25p badly in post - or 60i to 30p ?)
How were you viewing?
Stephen Neal is offline   Reply With Quote
Old 21-04-2006, 10:15 PM   #3 (permalink)
Probably down to deinterlacing but ....
Didn't have time to have a really good look to try and gauge the source (only had a few minuntes to spare).
I viewed them via Twinhan satellite tuner card via 2 methods - TSReader + VLC and via DVBapps .
If I had more time I could have switched a couple of different codecs in (in DVBapps) or , better still, saved to disk and done a proper analysis ; as it is I only used the Elecard codec in DVBapps.
If I have more time at the weekend I may well save to disk and have a closer look.
Viewing was on a Hitachi 21 inch CM813ETPlus monitor from ATI Radeon card in 3 GHz Northwood PC with 1GB RAM ; no stuttering etc. detectable.
Old 22-04-2006, 9:39 AM   #4 (permalink)
Thanks: Gave 6, Got 38
Weak signal with me for some reason ?? 1m dish
RecordablDVDfan is offline   Reply With Quote
Old 22-04-2006, 12:15 PM   #5 (permalink)
remlap's Avatar
Thanks: Gave 18, Got 61
Ive been watching this test since it started on Hispasat originally it had no audio at all!
Here are some screen caps by me.
remlap is offline   Reply With Quote
Old 22-04-2006, 2:15 PM   #6 (permalink)
Feed is dead now though ?
Old 22-04-2006, 2:44 PM   #7 (permalink)
remlap's Avatar
Yep dead.
Old 22-04-2006, 4:19 PM   #8 (permalink)
Was dead later last night - but I got video and audio no problem.
I saw the 1st 2 of the ones in the screengrabs (but don't recall the soccer one).
Haven't tried today (had to fix daughter's and mother's PCs + put new drivebelt on Flymo lawnmower).
30w, demo or tests, hidef, hispasat
Refbacks are On
AV ForumsOptimised for Firefox.
