AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 20-04-2006, 1:20 PM   #1 (permalink)
witters's Avatar
Thanks: Gave 178, Got 61
Showcentre 200 - help with serial No. please
Just bought one of these off the classifieds and there is no software disc. I have downloaded the latest software from Pinnacle but the serial No on the box isn't the correct lenght to insert into the software setup.
Can anyone enlighten me please?
witters is online now   Reply With Quote
Old 20-04-2006, 2:31 PM   #2 (permalink)
Tarbat's Avatar
Thanks: Gave 112, Got 262
Read the FAQ - http://pinnacle.custhelp.com/cgi-bin...?p_faqid=12219
Basically, contact customer support
Tarbat is offline   Reply With Quote
Old 20-04-2006, 2:33 PM   #3 (permalink)
Thanks: Gave 15, Got 0
Hate to be the bearer of bad news but the the serial number you need is on the paper sleeve the original software disc came in.
No idea how you'd get a replacement one other than calling Pinnacle Tech Support...
Best of luck, Pinnacle Tech Support are utter
It's a brilliant bit of kit when you get it up & running.
Chris
Anybody know a cheaper hobby?
ChrisN is offline   Reply With Quote
Old 20-04-2006, 2:35 PM   #4 (permalink)
Tarbat's Avatar
Or run an alternative server other than Pinnacles - something like Swisscenter for example, that's free.
Old 20-04-2006, 3:38 PM   #5 (permalink)
witters's Avatar
Thanks fellas.
200, serial, showcentre
Refbacks are On
AV ForumsOptimised for Firefox.
