AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 10-01-2006, 1:55 PM   #1 (permalink)
Thanks: Gave 1, Got 1
Will this really play HD ??
Or is it misleading. I can't see anywhere where HDMi is mentioned which i assume is the only way to watch HD ??
Or am I totally wrong and it will play HD lovely ????
http://www.pinnaclesys.com/PublicSit...Specifications
paulwilko is offline   Reply With Quote
Old 10-01-2006, 1:59 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,109
HD can viewed viz component outs, HDMI is required for a source with HDCP copy protection, (Or DVi with HDCP)
hornydragon is offline   Reply With Quote
Old 10-01-2006, 2:00 PM   #3 (permalink)
So are you saying that this will play any downloaded HD clips in HD then ?
Old 10-01-2006, 2:14 PM   #4 (permalink)
ahin4114's Avatar
Thanks: Gave 38, Got 54
Looks like it will do the job.
ahin4114 is offline   Reply With Quote
Old 10-01-2006, 2:15 PM   #5 (permalink)
Hmm, interesting. Question is, is it worth it ??
Old 10-01-2006, 2:28 PM   #6 (permalink)
waterloo's Avatar
Thanks: Gave 43, Got 9
how do i get hd clips ? my computer is 3 years old so i guess it wont download hd clips if i was to buy this where will i get hd clips on disc to play on it ?
waterloo is offline   Reply With Quote
Old 10-01-2006, 2:35 PM   #7 (permalink)
www.************ is a good start but apparently you need a decent pc to play them. I cant comment because i have a decent pc so cant prove it either way
Old 10-01-2006, 2:48 PM   #8 (permalink)
waterloo's Avatar
the showcentre will it play hd clips downloaded on a disc ? i have a mate who has a good pc can he download the clips for me on a disc and i can play them on this showcentre thing ? is there anything else out there like this that will play hd clips from a disc ?
Old 10-01-2006, 3:09 PM   #9 (permalink)
No it wont as far as i know
It is purely a streaming device from your pc to the showctre which is connected to your TV.
I believe that is correct.
Old 10-01-2006, 3:25 PM   #10 (permalink)
Tarbat's Avatar
Thanks: Gave 112, Got 262
See previous thread for full details - Show Center 200 Hi-Def Media Player
Tarbat is offline   Reply With Quote
play
Refbacks are On
AV ForumsOptimised for Firefox.
