AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 16-12-2005, 1:24 AM   #1 (permalink)
BadAss's Avatar
Thanks: Gave 138, Got 196
No HD-DVD from MS.
Looks like the HD format war is over. Blue-Ray wins!!!! I never doubted it for a second.
MS has no plans to release a HD-DVD drive for the Xbox360 in the future. It looks like there would be compatibilty issues with excisting 360s which are unable to play HD media.
Finally, we can all look forward to a single format. Wonderfull
BadAss is offline   Reply With Quote
Old 16-12-2005, 1:30 AM   #2 (permalink)
Thanks: Gave 4, Got 208
Xbox360 won't use BluRay either.. they've given up attaching an HD drive to it.
That'll put the Xbox at a huge disadvantage as a media center in the future (compared to the PS3) but I suspect MS don't care.. they're making a fortune on the games already.
Tony Hoyle is offline   Reply With Quote
Old 16-12-2005, 2:27 AM   #3 (permalink)
AML
AML's Avatar
Thanks: Gave 82, Got 128
The 360 simply isnt able to do much in terms of HD. Only the games and whatever 720p material is downloaded from live.
Its a bit dissapointing to be honest coz MS were trumpeting the 360 as an HD Media center. But all it really does is play games in HD.
It doesnt even play WMV HD disks! Thats like having a DVD player that wont play DVDs!
PC:Q9550 @ 3.6ghz, 8800GTX. X2 SLI
4gb DDR2 8500 Corsair, Asus Striker II Extreme.
Dell 30" @ 2560X1600
AML is offline   Reply With Quote
Old 16-12-2005, 8:45 AM   #4 (permalink)
Thanks: Gave 18, Got 28
A bit more info here: http://www.theregister.co.uk/2005/12...ox_360_hd_dvd/
John
johndon is offline   Reply With Quote
Old 16-12-2005, 8:55 AM   #5 (permalink)
Thanks: Gave 69, Got 314
Why assume "the wars over", just because a toy manufacturer has decided not to use it. A toy manufacturer that can't even get its goods into the shops on time.
Nick_UK is offline   Reply With Quote
hddvd
Refbacks are On
AV ForumsOptimised for Firefox.
