AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 14-12-2005, 1:55 PM   #1 (permalink)
mremulator's Avatar
Thanks: Gave 10, Got 46
T2 Extreme on Pinnacle/Snazzio/Buffalo Without Skipping?
I have been trying to get my copy of T2 Extreme to play without skipping on my ShowCentre 200. I have tried streaming it (wired ethernet), direct file access and playing it off my USB 2 HD connected to the player. It plays with sound but at less than 1/2 the correct framerate? The strange thing is that ALL my other HD movies including Gladiator/LOTR ROTK etc play perfectly?
WMV HD only has a bitrate of 8mbps, so It's not a bandwidth issue.
Has anyone managed to stream/play T2 WMV HD on their ShowCentre 200 or Snazzio without problems?
My Kit: Pioneer PDP-LX508D, Pioneer VSX-LX60, 2x Focal Chorus 816 WSE, 4x Focal Chorus 806 V, 1X Focal Chorus CC 800 V, REL Strata 5, SKY HD, SKY+, 2x XBOX 360's, XBOX 360 HD-DVD Drive, US Panasonic DMP-BD30 , Sony PS3, Panasonic TX32LXD60 & Marantz RC5400.
mremulator is offline   Reply With Quote
Old 14-12-2005, 2:24 PM   #2 (permalink)
Thanks: Gave 720, Got 847
This disc needs a US web site 'okay' to play first and is therfore 'protected', I don't think it plays on the machines you are talking about. You need a PC.
Do everything with excess, even excess
Nic Rhodes is offline   Reply With Quote
Old 14-12-2005, 2:31 PM   #3 (permalink)
mremulator's Avatar
Obviously besides the ShowCentre 200 does not have an optical drive ;-)
I have the files split into 4X 2GB chunks with the DRM protection removed. I also own the original BTW.
Old 14-12-2005, 5:01 PM   #4 (permalink)
Tarbat's Avatar
Thanks: Gave 112, Got 262
Any help here or here?
Tarbat is offline   Reply With Quote
Old 14-12-2005, 11:43 PM   #5 (permalink)
Assured Advertiser
Thanks: Gave 79, Got 719
Hello mremulator
I haven't played the Disc your enquiring about but can tell you it is possible to play it on the SnaZio SZ1350 - as long as the SnaZio is attached to a Network and the Network includes a PC (or MAC) that the DRM protected Disc has been inserted in and a valid licence key requested and then stored on the PC or MAC.
I believe there is an issue with the 5.1 Digital audio out at present when playing this type of Disc on the SZ1350 - you have to use the Analogue 5.1 Outs; though I know a fix is on the way.
Best regards
Joe
Joe Fernand is offline   Reply With Quote
Old 15-12-2005, 10:16 AM   #6 (permalink)
which is where I was coming from
Old 15-12-2005, 1:15 PM   #7 (permalink)
mremulator's Avatar
Like I said, it plays with sound (via analogue) but drops every other frame?
Definately not a bandwidth issue as 20mbps files seem to play perfectly
I think it's a firmware/codec problem on the ShowCentre. Plays perfectly on the PC BTW too.
Old 15-12-2005, 2:11 PM   #8 (permalink)
Thanks: Gave 38, Got 179
i thought that device was only capable of 720P WMVHD playback not 1080P, try reading over the specs...
meansizzler is offline   Reply With Quote
Old 15-12-2005, 4:01 PM   #9 (permalink)
Tarbat's Avatar
If T2 Extreme really is 1080P, then yes, the SC200 can only do 1080i and 720p
And Pinnacle clearly state that 1080p will drop frames - see http://webboard.pinnaclesys.com/read...&ThreadStart=0
Old 15-12-2005, 8:57 PM   #10 (permalink)
mremulator's Avatar
Old 15-12-2005, 9:31 PM   #11 (permalink)
Tarbat's Avatar
You need to establish whether it's interlaced or progressive.
extreme, skipping
Refbacks are On
AV ForumsOptimised for Firefox.
