AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 12-12-2005, 12:13 PM   #1 (permalink)
Phillips 37PF5520D component connection.
Hi, i'm new to this forum and could do with some help
I've just bought a Phillips 37PF5520D 37" LCD tv, I am having a few problems connecting my equipment to it properly.
I have a Yamaha RX-V357 AV amplifier which has 2 component inputs and one component output.
I would like to connect my Media Centre PC and my gamecube to the TV using the amp (so i dont have to continually switch inputs on the tv). The PC uses a VGA connector and when i connect to the tv's DVI input (using the supplied adaptor, it works perfectly in 1360 x 768 mode. If i connect the pc using the supplied vga - component cable (then a component cable to DVI), the tv displays 'no signal' on both the pc input and HD input. So obviously it's the same when i connect through the amp.
If someone could point out what i'm doing wrong, that would be much appreciated.
Basically, to sum up. How do i connect a gamecube (with digital cable) to the TV using a component connection. Do i have to use the RGB scart socket? Will that be able to display the pc input at it's native resolution? what will that look like?
Thanks in advance.
Chris
Chris How is offline   Reply With Quote
37pf5520d, component, connection, phillips
Refbacks are On
AV ForumsOptimised for Firefox.
