AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 12-12-2005, 12:09 AM   #1 (permalink)
chrisnic0's Avatar
Thanks: Gave 29, Got 12
HD with Dell 2405~ X800 surely?
Hi, im having trouble playing a trailer from mircosoft.
Stormchasers_1080.wmv?
Im getting video lag, ( not sure if thats the right term) but the video looks like its juddery.
Ive got an AGP X800 Pro which owns everything apart from this?
Ive got the latest drivers etc etc.
Ive even just have a clean reinstall, any ideas anyone?
Its playing 720p videos fine?
Nico
Sony MD 373 | Sony PS3 320Gb | Samsung R88 32" | Sky+ | Antec 400Gb HD |
PSN | chrisnic00
http://www.avforums.com/forums/membe...oom-setup.html
chrisnic0 is offline   Reply With Quote
Old 12-12-2005, 12:16 AM   #2 (permalink)
Thanks: Gave 1, Got 1
What are you using to play it? Media player uses so many resources that HD clips really suffer. Also, hardly any graphics cards have HD acceleration built into them so the CPU/GFX alone may not be enough to process the picture fast enough (remember stand-alone DVD decoder cards?)
kiran_mk2 is offline   Reply With Quote
Old 12-12-2005, 1:33 AM   #3 (permalink)
AML
AML's Avatar
Thanks: Gave 82, Got 128
You need a fast cpu to run WMV.
Preferably a 3ghz P4 or a 64bit AMD athlon 64. (2.6ghz)
Your card is probably fine. You also need lots of memory. 1gb or more if you can afford it.
runing HD on a PC requires uber specs for most 1080p stuff.
I can run 720p and even 1080i no problem, but it really stuggles to run 1080p on my 6800GT.
That was with HD Quick time, not WMV.
PC:Q9550 @ 3.6ghz, 8800GTX. X2 SLI
4gb DDR2 8500 Corsair, Asus Striker II Extreme.
Dell 30" @ 2560X1600
AML is offline   Reply With Quote
Old 12-12-2005, 12:23 PM   #4 (permalink)
chrisnic0's Avatar
Hey, yeah ive got a good spec PC
Ive got an Athlon 3200 64
1Gb RAM.
Im also using windows medai player 10?
Which other players play HD content?
Chris
PSN | chrisnic00
Old 13-12-2005, 11:51 AM   #5 (permalink)
dkboy22
Posts: n/a
1Gb RAM.
Chris
Try the VLC Player from:
http://www.videolan.org/vlc/
Plays almost anything and I find it uses fewer resources than WMP10.
2405, dell, surely, x800
Refbacks are On
AV ForumsOptimised for Firefox.
