AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 14-12-2005, 10:32 AM   #16 (permalink)
vipergrm's Avatar
Thanks: Gave 138, Got 125
Originally Posted by neilios
Hi vipergrm ,when i first got theatertek it stuttered quite alot too .
So the first thing to do is remove all the codecs you have on your system ,remove theatertek ,the nvidia purevideo ,even go into the registry if you have to and remove all traces .
Reboot ,reinstall theatertek ,reboot,start theatertek ,go into the video section and change the buffer to to less ,set video to full screen etc .
Hopefully this should sort out the problems your having ,i know it did for mine ,also i changed my nvidia drivers back to 81.85 ,as the new drivers were poor on my system.
Hope that helps.
Do you know what directory the Codecs are installed in? I will do extactly as you say. Thanks
Thanks Neilios
vipergrm is offline   Reply With Quote
Old 16-12-2005, 12:18 AM   #17 (permalink)
vipergrm's Avatar
Tried removing all the codecs, installed Theatertek and it's now worse than ever. In fact, it is completely unwatchable! I am going to see if I can get the 81.85 drivers. Again, I might try a clean install. What is likely to be the bottle neck? My CPU useage is around 40% and my graphics card is a GF 6800GT. I know people have far better results with less spec machines and that is the most frustrating thing about it.
Old 16-12-2005, 1:39 AM   #18 (permalink)
Thanks: Gave 4, Got 208
Are you sure the source material is clean and uncorrupted? Try a few mpeg2 demo files.
Tony Hoyle is offline   Reply With Quote
Old 16-12-2005, 6:38 PM   #19 (permalink)
vipergrm's Avatar
I have quite a few different HD videos inlcuding the original WMV DVD of Amazon. Doesn't matter if I play it on DVD or via Hard Drive. It all looks the same. I put on a normal DVD to see what it looked like and although it was much better, the jiddery movement was still noticeable. I'v tried downloading the older drivers but they don't seem to make any difference. All I can do is keep trying. Thanks for the suggestions guys. Much appreciated.
Old 16-12-2005, 10:21 PM   #20 (permalink)
Thanks: Gave 0, Got 6
The new graphics cards from nvidia 7000 series and ati X1000 series have h.264 acceleration which will improve playback of HD content alot.
MADMAND is offline   Reply With Quote
Old 17-12-2005, 12:27 AM   #21 (permalink)
Thanks: Gave 8, Got 8
Vipergrm
Try the Elecard mpeg player (free trial). When it comes to playback of HD, this baby is flawless.
http://www.elecard.com/products/prod...product_id=144
It is the only player that plays 100% of my HD library and with supreme results. VLC and WMP+nVidia PureVideo only score 90-95% from me.
Doc
VISUAL NIRVANA The Canvas - KRP-600M (and TH-50PF10), The Artist - Crystalio II VPS3300
AVR: Pioneer SC-LX81, Onkyo 705 BLU-RAY: Denon DVD-2500BT (UK), Panasonic DMP-BD50 (US) and DMP-BD35 (UK), Sony PS3 (UK) HD-DVD: HD-XE1, HD-E1 DVD: Philips 963SA SDI SKY-HD: Thompson, Pace
TheDoctor is offline   Reply With Quote
Old 17-12-2005, 2:37 AM   #22 (permalink)
vipergrm's Avatar
Originally Posted by TheDoctor
Vipergrm
Doc
Thanks TheDoctor - I tried the Elecard Media player and you're right. So far, that is the best I have done. It still isn't smooth though but cerainly more watchable than ever. Thank you for that. Judging by the spec of your machine you aren't likely to suffer from lag problems Thanks!
Old 17-12-2005, 2:40 AM   #23 (permalink)
vipergrm's Avatar
I agree the new cards run HDTV better but the gripe I have is that people running older ATI 9800 cards etc are getting a much smoother picture than me. I think I'm going to upgrade to a AMD 64X2 chip and a new board early in the new year. Hopefully this will do the trick
Old 17-12-2005, 10:28 AM   #24 (permalink)
Thanks: Gave 5, Got 7
I have been playing some hd demos on my laptop which is a P4 2.8Ghz, 512mb ram and a Radeon 9200 mobile graphics card. I've played numerous demos and most play with no stutter at all in the video but many really struggle with sound. So absolute power of the pc can't be that important imo as this laptop is only a moderate system.
Kit - -Panasonic TH42PHD8 ISF calibrated, -Denon 1920, -Denon 3806, - XBox 360/ HD-DVD addon -Sky HD, -Canton CD50 front CD10 rear, -SVS PB10ISD
NikB is offline   Reply With Quote
Old 17-12-2005, 4:40 PM   #25 (permalink)
Thanks: Gave 8, Got 385
The resolution of your laptop, and whether the source material is interlaced (and thus requires de-interlacing) can make a major difference in the performance of HD playback.
If you have a 1080/60i MPEG2 clip that you want to view, you can often get decent results on a lower resolution than 1920x1080 display, and if you de-interlace to 30p rather than 60p, or if the source is originally progressive 24p film, you can save a lot of processor overhead.
However if you want to watch a 1080/60i clip at 1080/60p on a laptop often you see the de-interlacing techniques eat into your processor power.
Other codecs like Divx and WMV are often only running at 24p - so have far less processing (as they are creating less than half the number of frames per second as a 60p de-interlacing process!)
Stephen Neal is offline   Reply With Quote
Old 17-12-2005, 9:23 PM   #26 (permalink)
Well I'm pretty new to the game so I wouldn't even know how to do half of that. Basically I've been using VLC without changing any settings and all of the trailers etc are 720p. I've hooked the laptop up to my plasma and it all looks awesome but the sound just isn't right.
Old 17-12-2005, 10:17 PM   #27 (permalink)
Starburst's Avatar
Thanks: Gave 93, Got 668
Perhaps the demos have DD audio and VLC is not configured to use it or the laptop isn't setup to output DD via digital link to a suitable amp?
Even more basic have you got a direct show filter (AC3 Filter) installed?
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
Starburst is offline   Reply With Quote
Old 18-12-2005, 10:01 PM   #28 (permalink)
vipergrm's Avatar
I think that is correct. When I plated HD content on my PC the sound wasn't 'all there'. I soon found out that I didn't plug in my centre speaker. DOH!
All the HD clips I have played seem to be in 5.1 so this may well be the issue.
Old 18-12-2005, 10:01 PM   #29 (permalink)
vipergrm's Avatar
Other codecs like Divx and WMV are often only running at 24p - so have far less processing (as they are creating less than half the number of frames per second as a 60p de-interlacing process!)[/quote]
Very interesting stuff. Thanks
Old 18-12-2005, 11:29 PM   #30 (permalink)
No idea if I have a direct show filter on this laptop. The laptop unfortunately doesn't have an spdif so I can't check that side of things.
hidef, jumping or skipping
Refbacks are On
AV ForumsOptimised for Firefox.
