AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 09-12-2005, 8:16 PM   #1 (permalink)
AVF Table Tennis Winner 06
Hi/zuum's Avatar
Thanks: Gave 156, Got 143
Analogue HD or Digital HD, which one's TRUE HD?
To my knowledge the xbox 360 outputs analogue 480p/720p/1080i signals via component/VGA, but the forthcoming PS3 is expected to connect via the HDMI & output a digital signal of 480p/720p/1080p? Isn't therefore the PS3 going to be TRUE Hi/def ?
Hi/zuum is offline   Reply With Quote
Old 09-12-2005, 10:10 PM   #2 (permalink)
Thanks: Gave 8, Got 385
You'll worry yourself into an early grave if you think there is a single "true" hi/def.
Analogue and digital interconnects can both deliver excellent HD pictures, and they can both deliver lousy pictures. There is far more in the source and display that can impact picture quality than just the interconnect device.
Everything else being equal, digital interconnect to a digital display should be as good, if not better, than analogue. However not everything else is always equal.
Stephen Neal is offline   Reply With Quote
Old 09-12-2005, 10:18 PM   #3 (permalink)
Hi/zuum's Avatar
I'm already talking from the grave, this whole LCD/HI/DEF debating killed me months ago...
Old 09-12-2005, 10:33 PM   #4 (permalink)
Thanks: Gave 22, Got 122
If your seeing a 720p image then it's high def, doesn't matter how it got there.
dan1979 is offline   Reply With Quote
Old 09-12-2005, 10:53 PM   #5 (permalink)
Hi/zuum's Avatar
...but isn't a 720p digital signal feed through a HDMI input into a HI/DEF LCD better than a 720p analogue signal through component.
Old 09-12-2005, 11:12 PM   #6 (permalink)
Melkor's Avatar
Thanks: Gave 9, Got 8
I thought that it depends on the type of material being played, e.g. VGA only gives a slightly better picture of fast-moving Xbox 360 games.
Melkor is offline   Reply With Quote
Old 09-12-2005, 11:18 PM   #7 (permalink)
Thanks: Gave 8, Got 8
I output 1080i from a PC using a component cable, which would probably put most DVI/HDMI connections to shame.
As Stephen said, all things being equal, the digital route "should" be superior but in reality this is not the case. Many digital inputs/outputs have restrictions and are not as flexible as their analogue counterparts (except the odd one or two).
Doc
VISUAL NIRVANA The Canvas - KRP-600M (and TH-50PF10), The Artist - Crystalio II VPS3300
AVR: Pioneer SC-LX81, Onkyo 705 BLU-RAY: Denon DVD-2500BT (UK), Panasonic DMP-BD50 (US) and DMP-BD35 (UK), Sony PS3 (UK) HD-DVD: HD-XE1, HD-E1 DVD: Philips 963SA SDI SKY-HD: Thompson, Pace
TheDoctor is offline   Reply With Quote
Old 09-12-2005, 11:33 PM   #8 (permalink)
In theory it should be, I can't see any difference between VGA and DVI on my projector.
Old 10-12-2005, 11:42 AM   #9 (permalink)
Thanks: Gave 1, Got 5
Not necessarily. Some people have found that the component picture looks better, and that HDMI can even look 'noisy' in comparison. It all depends on how the scaling engine in the TV processes analogue and digital signals.
Rimmer is offline   Reply With Quote
analogue, digital, true
Refbacks are On
AV ForumsOptimised for Firefox.
