AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 09-12-2005, 7:56 PM   #1 (permalink)
Thanks: Gave 3, Got 0
Will Progressive Scan Cure my Sync Problems?
Hello!
My Local cheapo catalogue outlet has a big stack of Philips DVP-3005 DVD players at £30.
When I play a DVD on my Samsung HDTV, on a Philips 720HDRW, the audio from my amp is .10 of a second earlier than the image, causing lip sync issues.
I understand this is caused by the TV needing time to downscale the image.
Can anyone advise me if buying one of these 3005's, and setting it to progressive scan, using the 3 component cables would cure my sync problem?
Thank you!
Dumpster is offline   Reply With Quote
Old 10-12-2005, 9:21 AM   #2 (permalink)
Thanks: Gave 0, Got 6
No it will not but you can now buy a box that will build a variable delay into the sound.
This costs about £150.Struggling to google it at present .Anybody else remind me of the name?
Alan
Hellicopter is offline   Reply With Quote
Old 10-12-2005, 10:25 AM   #3 (permalink)
Thanks: Gave 40, Got 66
Felston I think is the one you mean.
January 2007 Photo Competition Runner-Up
My Smug <<---------->> My Flickr
jmbrailsford is offline   Reply With Quote
cure, problems, progressive, scan, sync
Refbacks are On
AV ForumsOptimised for Firefox.
