Originally Posted by Rasczak
...however in reality it is going to be sometime before all amps have HDMI inputs and thus in the intrim many (most) people will use a seperate audio connection (optical or coaxial).
Even if there were a few that take HDMI audio it would be a start...
HDMI was designed to carry multichannel uncompressed audio, so the player/digital box would do the decoding. This should simplify the decoding process in the amp and make it easy to add new codecs because the amp would not need to know any of the new codecs. Instead it seems that HDMI will carry the compressed bitstream, which means the amp has to know the codecs. Since the HD codecs are new this is presumably why HDMI audio amps are so hard to find.
