06-12-2005, 4:41 PM
#1 (permalink)
Thanks: Gave 24, Got 12
YCBCR Or RGB Output Singnal ?
Hi All,
I hope you can help me with a small question,
I have a Sony NS92V DVD player conected to a Samsung LE40M61B LCD via a Ixos HDMI cable,
In order to get the best picture quilty do I set the HDMI Signal Output from the DVD player to YCBCR or RGB,
Please help a newbe if you can,
Cheers..
06-12-2005, 5:53 PM
#2 (permalink)
Thanks: Gave 16, Got 278
From the DVD I would imagine the best setting would be YPbPR as DVDs are natively encoded in component video.
06-12-2005, 9:10 PM
#3 (permalink)
Thanks: Gave 8, Got 385
Though it'll be YCbCr if it is via HDMI. (PrPb is analogue component, CrCb is digital component)
I think some displays only cope with RGB (probably the PC legacy ones connected via DVI)
06-12-2005, 9:17 PM
#4 (permalink)
 I didn't notice that.
06-12-2005, 9:38 PM
#5 (permalink)
Thanks for your help Guys,
YCbCr is the way to go for me..
06-12-2005, 10:41 PM
#6 (permalink)
Thanks: Gave 322, Got 315
It'll be down to the difference in the transcoding performance between the player and the display.
It'll be worth experimenting, but I doubt you will notice the difference, it's a rather subtle one.
07-12-2005, 2:18 AM
#7 (permalink)
Also, if the player is outputting an HD upconvert of the SD YCrCb it may be worth taking the RGB output, especially if the HD YCrCb output is 4:2:2 not 4:4:4, as you would then avoid a second chroma sub-sample?
07-12-2005, 3:33 PM
#8 (permalink)
Thanks: Gave 158, Got 43
Originally Posted by Goonerdude
Hi All,
Cheers..
I was unsure of this , and spent quite a time reading about the differences, mainly on american forums !
anyways
YCBCR unless you get distortions to the colour this may appear as smearing or something !!, if so switch to RGB
I have not seen any distortion myself, but kid myself that the YCBCR output looks more natural !! err I think.
Rich
07-12-2005, 7:14 PM
#9 (permalink)
Thanks for all the replys,
Still playing around with the output but YCBCR looks like a slightly sharper picture to my eyes, but will keep on playing with it,
Rich, you are right YCBCR does look a bit more natural but there is not much in it,
Must find some time and watch more DVDS,
