AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 06-12-2005, 10:51 AM   #1 (permalink)
mremulator's Avatar
Thanks: Gave 10, Got 46
Specific ShowCentre 200 Help Needed!!!
Basically, I'm really struggling with this and would really appreciate some help!
I noticed that there are 3 different software/firmware updates. So firstly I installed the software that came on the installation CD, then connected the ShowCentre Player and updated the firmware. I then uninstalled the software on my PC, installed V2.2 and updated the firmware. I then uninstalled V2.2 and installed V2.3RC1. I have also paid for Dolby Digital activation. I'm using the ethernet connection by the way.
Anyway, would someone be kind enough to help me with the following:
1) I can only see the Dolby Digital Option when Using V2.2 firmware? Even though there is no firmware update in V2.3RC1 it has still removed this option? Is this normal?
2) It says that you can import WMV HD files with DRM "· All new features of v2.10 beta (import of DRM-protected files", however, it rejects them in 2.10, 2.2 & 2.3RC1? Other files are also being rejected?
3) Even if I use direct file access, files with DRM refuse to play?
4) 720P WMV HD files play but drop frames, however 1080i files play perfectly? Even the high bitrate stuff (16MBPS+) play fine.
5) If I install Windows Media Connect, the 2 devices can not be seen nor selected? I just get a white empty screen? Do I even need Windows Media Connect anyway?
Any help with this would be greatly appreciated!!!
My Kit: Pioneer PDP-LX508D, Pioneer VSX-LX60, 2x Focal Chorus 816 WSE, 4x Focal Chorus 806 V, 1X Focal Chorus CC 800 V, REL Strata 5, SKY HD, SKY+, 2x XBOX 360's, XBOX 360 HD-DVD Drive, US Panasonic DMP-BD30 , Sony PS3, Panasonic TX32LXD60 & Marantz RC5400.
mremulator is offline   Reply With Quote
Old 06-12-2005, 1:01 PM   #2 (permalink)
jaymz's Avatar
Thanks: Gave 108, Got 69
I have answered your other thread
AV46M87, RX650,Monitor Audio B4/BFX AV
MCE Silverstone LC20m,Q6600 Go, P35C-DS3R, Freezer7Pro, HD3450 Silent, 2TB Spoint, 2GB, WinTV Nova-T 500 & Nova-T, HD-dvd drive
PC X2 4600+, A8N-VM CSM, 2GB , 250GB Spinpoint, 600GB IDE, Zalman 7700 Netbook Samsung NC10
jaymz is offline   Reply With Quote
200, needed, showcentre, specific
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Urgent Help Needed How Do You Print A Page. Garrett Computer Systems 9 21-01-2004 10:43 PM
Lowish £ Amp needed with specific Reqs... Jenz Integrated AV Amplifiers and Receivers 5 05-12-2003 2:48 PM
BK XLS 200 Subwoofer Review (Long Post) pauljames Subwoofers 21 19-11-2003 12:56 PM
Saying hello - and advice needed duncs CRT Televisions 4 01-09-2003 5:46 PM
Arcam Power Amp Help Needed! Matt Horne Audio Processors and Power Amps 3 15-11-2002 10:25 PM
AV ForumsOptimised for Firefox.
