very comprehensive first post! I'll try with a couple of answers
1) Hype and Marketing. High Definition is High Definition. The difference comes when you want that little 'HD Ready' logo. To get that logo you need a bunch of things, including a HDCP compatible digital input (HDMI, DVI with an adapter). You also need component input and support 1080i and 720p at both 50 and 60 fps.
This in theory makes it easier to match a prospective purchase with a new service. Eg buy a HD ready set, don't worry it'll work with Sky HD.
It also makes it more complex for existing TV owners.
Xbox 360 will still be HD. It'll also be reasonably flexible. You'll be able to set it to output what your set prefers, and it'll scale internally. eg if your set prefers 1080i, it can be set to that.
3) in theory, slightly. Its just digital Vs analog. If you are feeding an analog set, or a digital set that has an analog conversion internally, then the difference will be minimal at best. On a completely digital set, like a plasma or LCD, the difference may be noticeable, but its debatable.
IMO, HDMI is there for copy protection, not for simplifying things for consumers. Wouldn't worry about it, other than some equipment may require it to be present (eg High definition DVD/bluray players for copy protection)
4) Suck it and see. Sorry, but technology is pretty mature for these devices, and some prefer the 'look' of one over another. Your eyes are the best judge. If you like it, thats the best one for you.
6) Should do. At least your TV will accept 720p inputs. Probably won't resolve that on screen (It'll do some downscaling). Do some experiments when you get the xbox. You may find better results running 1080i from it
8) Samsung 40" or Sony V series 40". Both seem pretty close in HD image quality from what I've seen, but the Samsung is about £400 cheaper.
