Originally Posted by mekes82
and what inputs the TV should have. Im hoping to take advantage of SkyHD and play PS3 and XB360 under HD settings.
Just thought I'd point out the the connections you'll need for such devices.
Overall, you'll need at least a HDMI, a VGA and a Component connection. Might be wise to try and get one with a DVI-I to, that'll give you one extra connection to play with.
XBox 360 - You will be able to connect the XBox 360 to a VGA socket, or a DVI-I (DVI-I specifically, not DVI-D) with a simple adaptor. You may as well try and get a set that has both - heck why not?
PS3 - Said to have 2 HDMI outputs, so you'll need HDMI for that.
Nintendo Revolution - Component.
SkyHD - No-one really knows what this will require, though HDMI is expected.
