AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 23-09-2005, 1:21 AM   #1 (permalink)
HD On PC
Ok i have a panasonic tx-32lxd500 LCD tv and would like to be able to watch hd clips on it, now i know that i will need to connect the my pc to the tv to watch these. Now here's the problem my tv has a hdmi slot and to connect it to my pc i would need a 10 metre dvi adapter cable and a 10 metre audio cable but i do not yet have a graphics card capable of using dvi so i will need to buy one, the other option is to buy a laptop with a dvi and connect it by this, i was thinking of getting a laptop anyway for other things but would need to buy a high end one to get in with a dvi connection, also my manual for my tv says under the hdmi connections section that this inout terminal is not intended for use with computers or do i scrap all these and use the normal pc connection how do this compare to the hdmi slot for quality. sorry this is so long winded but it is going around and around in my brain and i just need some help.
blp21 is offline
Old 23-09-2005, 2:30 AM   #2 (permalink)
Kramer's Avatar
Thanks: Gave 5, Got 31
I''d suggest a cheap DVI equipped graphics card. Just so you can do some testing, see how it goes etc.
Should be available for as little as £15 nowadays.
Kramer
My personal opinions expressed here are not necessarily those of the AV Forums or other related websites, but you all know that
Kramer is offline
Old 23-09-2005, 12:03 PM   #3 (permalink)
Mandarin Man
Posts: n/a
If you have a 16:9 LCD monitor or TV, do you need a special videocard that supports 16:9 resolutions like 1920 x 1200? Which videocards support 16:9 resolutions?
Thanks,
Roy
Old 23-09-2005, 4:39 PM   #4 (permalink)
ok but if i bought a cheap dvi card would it be powerful enough to play hd movies
blp21 is offline
Old 23-09-2005, 4:58 PM   #5 (permalink)
Thanks: Gave 5, Got 355
Thanks,
Roy
You shouldn't need a special video card - though you might need to use Powerstrip to create a custom video mode if your video card drivers don't offer 16:9/15:9/16:10 resolutions when you connect a suitable display.
I have a 1024x576 16:9 SD resolution on my HTPC using Powerstrip and a VGA to RGB SCART cable, but didn't need to use Powerstrip when I connected a widescreen LCD display via DVI. This was with a low-cost Radeon 9600 Pro, and with a 2.8 Athlon is fine for decoding HD MPEG2 stuff.
Stephen Neal is offline
Old 23-09-2005, 5:47 PM   #6 (permalink)
Mandarin Man
Posts: n/a
What if you use a 16:9 LCD computer monitor. You would need a 16:9 capable videocard then, right?
Blp21, check the system requirements for the video that you would like to display. Get at least a 128mb card for HD material.
Roy
Old 23-09-2005, 7:08 PM   #7 (permalink)
Most video cards are 16:9 square pixel capable - it is a driver issue not a hardware issue. Some video drivers correctly interpret the monitor data flagged by the monitor when it talks to video card to indicate what resolutions it copes with - and if it is a 16:9 monitor (or 15:9 or 16:10) then it corrrectly signals 1920x1200 or 1600x1050 etc. and offers that as a resolution.
If you are feeding a 16:9 display that doesn't correctly flag its resolution, or using a video card with drivers that don't natively support 16:9 modes you may need to use a custom Powerstrip mode. However most cards these days won't struggle to offer 16:9 video. Hardware acceleration of MPEG2 decoding may help though - so more powerful cards might be useful!
Roy
Yep 128Mb is a good minimum for HD stuff.
Old 24-09-2005, 1:58 PM   #8 (permalink)
where can i find a 5metre audio cable to connect between my hdtv and my pc
blp21 is offline
Refbacks are On
Thread Thread Starter Forum Replies Last Post
HD Ready & PC Friendly 32" LCD's...? HSC LCD Televisions 32 10-08-2005 4:22 PM
Proper HD - Not for 5 years ? paulfoley High Definition TV Hardware 17 18-07-2005 8:00 AM
Is my PC up to the task of HD playback? DGtal Computer Systems 2 12-07-2005 12:48 PM
HD PVR to PC jimbowley PVRs and VCRs 7 05-11-2004 8:17 AM
HD Help & Advice Please soni High Definition TV Hardware 6 24-10-2004 6:20 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
