Originally Posted by Dutch
Yep - had stumbled across that. Saw a demo of a BBC R&D solution to the 1080/50p via an HD-SDI connection problem at a recent open day. They have developed a low latency (8 lines of delay) mezzanine compression scheme that compresses a 1080/50p signal into a 1080/50i HD-SDI video signal. Even more clever is that the compression is devised in such a way that you get a low quality 1080/50i signal as part of the compression - so can monitor the feed for identification purposes with a regular 1080/50i monitor.
It uses a bit more than 2:1 compression - but does actually deliver a solution that would be compatible with existing routing infrastructure - though peripheral devices like vision mixers and VTRs would require compression and decompression units.
(NB Am I the only one who finds the EBU nomenclature of 1080i25 and 1080p25 misleading? It implies that 1080i25 only provides 25 images a second - whereas, although it runs at 25 frames per second, there are 50 separate fields, all potentially taken independently at 50 different points in the second. I much prefer 1080/50i personally...)
